I have been running my C34 on E10 for years. It is tuned for it. I don't know if you will see any benefit if you don't have any means of tuning your car although it may clean up the fuel system. Tip: after running on E10 for 1000km or so change your fuel filter(s) as any gunk in the tank may have been liberated!
I am keen to change to E85 but its not readily available at the pumps and I'm not prepared to buy it by the drum as I could be stranded when away from home.
https://www.sau.com.au/forums/topic/393660-e10/#findComment-6260801
My local united has no e10 anyone know of a station with e10 around rowville/ Knox area? Melbourne....
List of stations that have the Premium 100
http://www.unitedpetroleum.com.au/store-locator/fuels/Premium-100
Closest United Servos to Rowville
=3178&distance[search_distance]=20&distance[search_units]=km"]http://www.unitedpetroleum.com.au/store-locator?distance[postal_code]=3178&distance[search_distance]=20&distance[search_units]=km
https://www.sau.com.au/forums/topic/393660-e10/#findComment-6261824
    • And 90% of the time those people turn out to be wrong anyway. But they still treat themselves as a victim...
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
