ok guys time to move on from this car, ive had it for 2+ years, im first australian owner
car is a 1988 Nissan Cefiro
gna start of by saying CAR SPUN A BEARING LAST WEEKEND AND WILL BE SOLD MINUS ENGINE
SPECS LIST:
engine:
RB20DET rebuilt by Donny at StreetForced and Mick at Headtech Cylinder Heads
GReddy TD06L20G turbo
GReddy external wastegate
GReddy high mount exhaust manifold
GReddy dump/front pipe
GReddy returnflo front mount intercooler kit
GReddy water temp sensor
HKS camshafts, 264/8.5mm
HKS cam gears
JJR oil cooler and relocation kit
JJR silicone bottom radiator hose
Supertech forged pistons 20thou oversized
ARP rod bolts
ARP head studs
Cometic metal head gasket
Cometic gasket kit
new genuine Nissan oil pump
new genuine Nissan water pump
new genuine Nissan idler pully
new genuine Nissan tensioner pulley
NDC bearing kit
Gates timing belt
grub screwed, balanced and ground crank
balanced pistons
balanced and resized rods
decked, bored and honed block
resurfaced head
valve grind
new valve stem seals
exhaust guides and ports cleaned up a bit
braided oil lines
braided wategate vaccuum line
Blitz 3" cat back exhaust
custom twin 3" straight pipes from diff back
Splitfire coilpacks
Koyo copper core radiator
Nismo thermostat
Z32 AFM
R32 GTR injectors and resistor pack
Status remaped ECU
Walbro fuel pump
gutted cat
Cusco catch can
RedTop RB20 rocker covers
RB20DET-R intake manifold badge
battery relocated to boot
metal intake pipe
Apexi pod filter
driveline:
RB25 5speed manual gearbox
new OEM Nissan slave cylinder
custom one peice tailshaft
ORC single plate clutch
KAAZ 2way lsd
Redline shockproof gbox oil
brakes:
R32 twin piston front calipers
R32 front discs re drilled to 4stud
R32 rear discs
R32 twin piston rear calipers
R32 5 stud rear hubs
HKB 10mm extended rear wheel studs
BM44 brake booster
Cusco BMS
suspension:
Whiteline adjustable rear swaybar (27mm)
SuperPro steering rack bushes
JJR front swaybar (30mm)
JJR solid steering shaft bush
JJR rear strut brace
MidnightMods rear subframe risers
TuneAgent castor arms
JIC camber arms
JIC FLT-FAS coilovers
Cusco front strut brace
Ultra Racing fender braces
PoweredByMax rear toe arms
interior:
GReddy boost guage
Defi oil temp/pressure and water temp guages in DIN slot
JJR drift handbrake button
Juran seat rail
Bride Brix 1.5 drivers seat
Bride centre console
R32 GTS-T passenger seat
Cusco C33 laurel bolt in rollcage
Cusco bolt in cross bar
Nardi 350mm deepcorn
Nardi boss kit
aftermarket gearknob
Factory Nissan floormats
Kenwood headunit
JBL front and rear speakers
deleted all a/c related parts
deleted all sound deadening
fire extinguisher
dash loom and fuse box stripped to run bare essentials
exterior:
Autech body kit
Nissan factory weathersheilds
late model "laurel style" chrome grill
roof spoiler
gas bonnet struts
R34 GT-t rear windscreen wiper
GKteck bash plate
pumped guards
wheels and tyres:
front:
17X9.5 +5 SSR Proffessors (shadow chrome)
rear:
17X9.5 +22 SSR Proffessors (shadow chrome)
have listed engine specs as im willing to sell the motor with the car if you want it for 2k extra for block,head, injectors, intake manifold (no turbo kit)
interior is in mint condition, body is fairly good, has slight paint fade on passenger rear pillar and front bar is pretty beat up but have a spare in mint condition, could do with a new passenger front guard aswel
asking 12k as is with no engine and 3 months rego in VIC
have spent over 30k on this car
drop a 20 in and off you go
can do different deals with motor, turbo kit, gearbox, clutch ect
massive build thread here if you want to read the whole journey of the car from a stocker import
http://nissansilvia.com/forums/index.php?showtopic=403977&hl=&fromsearch=1
have another car i want so this needs to go as i have no room for 3 cars
https://www.sau.com.au/forums/topic/393662-vic-88-cefiro-no-engine/
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
