More info, It is a NSW rego, it was on the car when we bought it and we are driving the car to WA so it will not be needed, when we get there and it is rego,d in WA.
I dont know if i am allowed to do this? but if not im sure a mod will delete it.
If someone is interested in it it will possibly be for sale in the near future. Just PM me here if anyone is interested.
Hi, I have also got a collection of Vic plates{ hope you don't mind me hijacking you thread)
Here they are, don't know how much they worth.
GTRHKS
N1SMO
MYNUR
A350Z
R34GTT
CHEUNG
AC111
S1LV1A
NATO88
CITX
PM or call 0433878905
OK the car is now in WA, at the moment we are running around with these plates on it. If someone is interested just let me know. When i get the WA rego sorted out it will be availible.
Red plate with white letters.
  • 1 month later...
I have been told ny a rego selling company that i can not sell the rego GTR 35C that came with my car. Bugger. she said this.
Personalised plates in the format of 3 x letters, 2 x numbers and 1 x letter cannot be sold in NSW as you can only transfer the Right to Display the plates to an immediate family member. Therefore you cannot sell them to anyone who does not meet this criteria.
Only fully customised number plates can be transferred to any other individual.
myplates.com.au
Is this correct? If so it will just be an ornament on the garage wall. :)
myplates.com.au
Meh, heaven forbid you want to give them to a long lost orphaned brother or sister.
Then again, the NSW custom number plate scheme is expensive and quite frankly rooted. Victoria does it so much better (for the consumer). gosh darn the RTA (or whatever they are called now).
    • Middle seat good for a slab of beer or Esky for a road trip. 2x kids, means 1x free seat lol.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
