I have the OEM mat, it isn't that great as all the crap slides around in the back now. Im sure there is a better material to make it out of, even plain rubber would work better as Josh said.
Great for taking the dog for a drive though.
https://www.sau.com.au/forums/topic/393710-m35-cargo-mat/#findComment-6261341
There's a sweet mat that actually goes up the back of the rear seats and the headrests go through it. So when you fold the seats down and presumably put a bike/snowboard/etc in there, it's covering the whole lot instead of just the "cargo area".
But yeah, only ever seen one on YAJ and it was stuffed.
https://www.sau.com.au/forums/topic/393710-m35-cargo-mat/#findComment-6261344
Luckily I have both of the factory mats, the rubber mat and the mat that runs up to the back of the seats for when you fold them flat.
About 2 months ago I did see a set of mats that covered the wheels arches that matches my mat but I forgot to bid on them. Never seen either of the mats before or after that on yahoo.
https://www.sau.com.au/forums/topic/393710-m35-cargo-mat/#findComment-6261362
Wouldn't be too hard to get a trimmer to make one up, surely. Just got to find one that works for cartons.
Best bet would be for someone that has one to take it to a trimmer and get them to replicate it.
Is that the sound of a group buy starting up Jase?
https://www.sau.com.au/forums/topic/393710-m35-cargo-mat/#findComment-6262631
I guess it would really depend on what everyone wants.
I'm pretty happy without one, but if I was going to get something it would be some sort of carpet that went up the back of the seats like we were talking about above, but with a washable, water resistant carpet. That way after a muddy day on the bikes it can be pulled out, hosed off and chucked on the line to dry.
https://www.sau.com.au/forums/topic/393710-m35-cargo-mat/#findComment-6262644
So you would want it out of a marine type carpet? The factory one isnt carpet, it's a thin fabric with a thin rubber back.
I'll see what they can offer.
That's what I used. Just cut the right width and then make the cuts so that it sit nicely with the seats down (and covers the headrests too - my dog put his claw through the leather on one of them).
Cheap, easy and works very well.
https://www.sau.com.au/forums/topic/393710-m35-cargo-mat/#findComment-6263046
I suppose. The fabric with rubber back would be just as suitable I guess. I'm not really that serious about getting one to be honest..
https://www.sau.com.au/forums/topic/393710-m35-cargo-mat/#findComment-6263055
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
