I have an auto 33 gts , but it says all 1995 33 auto gas's have an rb20? I have an rb25?and how do I tell if my hicas works?
http://en.wiktionary.org/wiki/myne
just for everyone who doesn't speak 'lazy-teen'
On your cluster you should have the word HICAS that gets highlighted for a few seconds along with ABS, Airbag etc when you turn the ignition on, if the HICAS stays highlighted permanently then theres usually something wrong with it.
i dont see how "myne" is easier to write than "mine".
Upon further consultation of my keyboard, i is closer to both m and n therefore, it would take substantially less time and effort to just type mine instead of myne and making this generation look stewpid.
I didnt draw attention to any of the other peculiarities, but now i will..
What is a "gas's", and how does it relate to your NA R33 Skyline?
ea it says rb25 , just couldn't find my model on the net? :/And the only NA skyline to have a LSD is the series s gts25 or something?
What is "ea"?
Also, this isn't a jab at the OP, but how could you buy and own ANY car, not just a skyline, and not have any idea what model it is?
I understand that i am a car enthusiast, but isn't it standard procedure to find out at least what model car you are purchasing before you hand over your hard earned?
Edited by adamskill
What is "ea"?
5 bucks says he's on his p's and has no clue what car he drives other than skyline!
Make a few spelling mistakes cause I'm getting used to my iPad On my L plates , first car..Appreciate lots of different cars......Sorry for asking for some help and people just dribble on about spelling when it's fine to read? Sit down you clowns....if your Gona be funny go for it , if your not then dont waste your time , twats
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
