Hey guys in need of a boost controller. Don't know allot about them but need one before my tune.
What are people on here running?
I hear the greddy is popular
I can get the blitz spec s for 100$ less then the greddy Profec b 2. Which one would be the way to go?
Thanks in advance
https://www.sau.com.au/forums/topic/393897-boost-controller-opinions/
for $100 less go the blitz.
basically the same EBC.
I have the blitz spec 2 in my car and it holds 20 psi with about a 1.5psi drop around 6000-7000 revs
which TBH is fine by me at that rev range ;)
one thing that is important to remember regardless of what controller you use is that be careful and aware of the pressure difference between the actuator or gate spring and what you want to run
ie if you run 7psi spring and you want run 22psi thats a lot of work for any controller and the results might be spiking boost / tapering off boost or inconsistent
you should run a spring that suits your "mininmum possible boost" and then use a controller to let you bleed a few PSI over that mininmum
ie if you want 21 psi then run springs that give you say 17psi minimum and bleed the rest via controller
and lastly if you see boost pressure taper off in the rev range its probably excessive exhaust back pressure (housing too small or boost too high)
I had a profec B which was ok until you start running over 20 psi.
as per above - any controller can let you run any pressure
ie 57psi if you like providing the base spring level is half reasonable
it sounds like you might have had the wasgate spring too low, ie 7psi spring trying to bleed 20psi
and/or the housing is too small or exhaust back pressure is excessive
even with a 15psi spring a small housing can yield poor boost control as well or "tapering off boost" is what most people see
and they usually blame controller and try to find a better controller that can hold boost
ive got a powerfc boost kit for sale to suit ecr33 for cheap
If you have a power fc this would be my first choice, my second is a Gizzmo ebc, i have one and it works great and is not expensive because it is only an ebc, does not have any other wank factor attached, i would recommend almost any other ebc before a boost T or adjustable wastegate, the way an ebc works much better than any boost T.
Edited by W0rp3D
there are a few additional features the powerfc boost kit has over a seperate controller
1 - plug and play no extra wiring or controllers
2 - boost displayed on hand controller
3 - boost correction is enabled on the ecu
4 - safety fuel cut if boost exceeds target by 0.25kgcm2 - ie split vac lines
5 - you can use the boost reading in logging if used with datalogit to better tune boost build
With an ebc set up right you don't have to worry about boost creep or drop off, personally I have spent the money on an ebc as its more accurate than the old hks adjustable wastegate I had.
thanks for all the replies
I ended up going for a boost t as my tune was brought forward and it was the cheap alternative to the space in time I have
maybe one day ill end up with an ebc as ones you guys have recommended
@gtsttrk - boost levels between 12-14psi
Yeah mate just FYI for down the track any of those controllers would be fine for those levels of boost:)
EBC can't be beat for maximum power and drivability, but for small to moderate power increases, the Turbotech boost T does an amazing job given it's cost. Never spiked or failed me in any way and I've never heard a bad thing about them!
    • Update time!  The JZX110 had some maintenance needing to be done, so a lot of the seals with replaced to fix some oil leaks. Also used this opportunity to whack on a front mount that I'd bought some time ago.  I also finally got the rear lip painted and fitted.  I then got the exhaust done. It's just a catback for now. Custom made 3" stainless with a turn down. I could have a tip coming out, but it will require cutting the rear lip and possibly the bumper itself. So far I do like and it's made the car a little more zippy.  Close out with some nice pictures of the cars and a sneak peek of what's next.
    • Once you learn it all, you find you do the job once. But this is the best way to learn, as you won't forget the lessons
    • Edit: It's now known as "R Performance" and is still in operation.
    • This lady loved her FD for 25 years!  https://www.topspeed.com/80-year-old-woman-donates-fd-rx-7-mazda/ My brother in law. He's nice enough to let me drive it whenever. He'll likely not see this, but I'll try: @r-is-for-fun got any pics?
    • Just something I found searching for more info on Emotion R, apparently the ECR33 Skyline GTS25t was either originally black, or there were two of them, the black one being the original demo car, then building a white one which was part of the 1997-onwards (to at least 2008!) Cockpit Tatebayashi Tokyo Auto Salon booth demo cars. It appears that Emotion R closed down in 2008 and was declared bankrupt in 2010: http://bank-db.com/hasan/208365. Scan of a magazine with the black R33 from 1996: Wayback machine archived page from May, 2000: https://web.archive.org/web/20000529061027/http://www.emotion-r.co.jp/skyline.html Option magazine with a few photos from the Cockpit Tatebayashi booth at the Auto Salon from various years: 2002: http://www.jdm-option.com/photo/index.php?action=item&category_id=154&image_id=3507 2003: http://www.jdm-option.com/photo/index.php?action=item&category_id=137&image_id=3033 2005: http://www.jdm-option.com/photo/index.php?action=item&category_id=116&image_id=1831 In 2008 Cusco website mentions that the Cockpit Tatebayashi ECR33 was displayed at that year's Tokyo Auto Salon: https://www.cusco.co.jp/event/2008/12/post_735.html As of 2021 it appears that the ECR33 demo car ended up being exported to Florida, USA: https://rmcmiami.com/inventory/1996-nissan-skyline-r33-cockpit-tatebayashi-demo-car-big-te06-turbo-endless-brakes-lsd-450hp/ And finally here's Google streetview of the Emorion R garage in 2023 which is amazingly not only still there, but the showroom is still full of various parts in stock and funishings, etc.: https://maps.app.goo.gl/ttyEAZdZLyzermyT9 Apologies for nerding out a bit. I used to love doing this 20 years ago on SAU and got a bit nostalgic for a moment... 😅
