I have set of height and damper adjustable coilovers to suit r33/34gtr, in very good condition and not as harsh as many but still give very good handling $900, will post pics soon
these can also fit r34 gtt, the rears are perfect and the fronts with my supplied spacer plate will fit fine but are very low and scrape slightly on hard lock, but if you like it low and are carefull they will be ok
will ship at buyers expence, email [email protected] for direct pics
also have a set of brand new r34 gtt shocks with springs $150neg
r34 gtr front shocks and springs $150neg
rb25 plenum lower half runners $50
rb25 crossover pipe with BOV $50
std cam gear rb $20
rb25 throttle body no tps,$40
rb20 throttle body no tps $40
have other stuff will post soon
Want to swap the coil overs with lowell or whatever my lowered springs are (australian made according to my friend) plus cash? It's off r34 gt-t
no sorry dont have the 34 anymore so dont need any shocks
the ride is firm and handles very well, not as harsh as some cars with tein coilovers i have ridden in but thats just my opinion, very hard make deffinate comment with so may variables
Hi Clint,
When you say they are low (front) is that with or without your spacer? I think they are actually R Tune as the S Tune are not height adjustable according to the Nismo site.
Then again I could be wrong, either way, a great set of undercarriage
Cheers
Muz
Hi Clint,
I would love the rears but the fronts are going to be tooooooo low for mine. Nismo site says R Tune = 9 on the front and 8 on the rear, S Tune = 6.8 on front and 4.6 on the rear.
Cheers and good luck with the sale Clint
Muz
So they are still TOO low on the highest setting - at the front end?
I thought being adjustable [height] you would be able to set them at a nice comfortable level :confused:
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
