Hey guys, i was wondering if its possible to put a aftermarket intake manifold/plenum or a rb26 plenum on the rb25de non turbo, reason i want to do this is because i want to eliminate the cross over piping on the stock plenum, which goes over the motor and gets freakin hot, defeating the purpose of a CAI. If it is possible, will i need to do make any modifications to the ecu, air sensors, throttle body(can i use the stock throttle body) etc..?
Cheers guys
hey man do a search i asked this like a year ago, the answer is don't waste ur time ull more then likely lose power due to losing velocity or something, its covered i. the other post.
Ahhh thats fair enough i guess, cheers for that
as above, don't bother.
also don't confuse a hot pipe with hot air. ever done that thing where you pass your hand quickly over a flame without getting burnt? the same principle applies to intake air. at wide open throttle the air is moving at high speed so it isn't affected by intake temps much at all. even at low throttle it isn't affected by much
  • 7 months later...
Just saw this post i made few months back, i actually cant believe i asked this question.
I think everyone's done this, I once started a thread regarding gilmear drives for an rb25 (facepalm)
Everyone just needs to remember the search button is your friend,95% of stuff has been asked already.....
And still an extractor/exhaust NA question pops up every 2 weeks :dry:
Edited by Nikk_666
Haha thats true mate, yea i actually found a few searches regarding this very question, still pretty stupid question. Not even a turbo haha.
And yea i see alot of those questions as well, i actually had a canon tip on my car when i first got my Ps in 2010, removed it and bolted on the factory muffler 3 months later when i actually understood more about cars. All i did by chucking on a canon was eliminate back pressure, and make it droney as fk. Lost so much torque, extractors and exhausts are next to useless on non turbo rb25s, people need to understand that. Ive actually beaten a few skylines with full custom exhausts, even r34s, its just rubbish, no point. Just loses back pressure and makes noise.
At the end of the day, so glad my knowledge of cars has improve by x10. =p Sucha stupid post haha.
2 of the big ones, and by tonight
A couple of backpressures would pull a premium a week before racewars...
Do you think we can overnight the parts from Japan?
    • Gas MIG for learning, I was able to weld up some nice 1.6mm tubs so you can do thin stuff easily enough. Then moved on to thick caliper adaptor brackets with the same machine, all good.  Arc/Stick is great for dirty garden work etc, but Gas MIG for starting on car stuff.  Jump on the NCR FB page and search ATP Tubs or GKTech caliper adaptors for pics/info. I'm no pro but it wasn't hard to learn. Be willing to grind and go again though if it's cold etc.
    • That's not a bushing!
    • Oh and I got myself a grandpa spec dash mat.
    • Ok, so first round of maintenance done. I didn't get much history with the car but I know it was well looked after. That isn't enough for me though, so ...  I had to do the oil filter housing gasket. It was leaking a lot, and also as part of that I did the anti-return valve and the VANOS oil line (from HEL).  But, then I got hit with the while-ya-in-there's. Did both accessory and A/C belts, tensioners and pulley. The accessory belt that came off had a huge hole in it, like somebody hung it up with a nail. The pulley and tensioners seem ok, so I'll keep those just in case. I did water pump and pump pulley. The water pump had a small bit of play so timing was good.  I also did fan clutch. I don't know how to test the old one but between the water pump and the fan clutch the car is running a little bit cooler (not much ~2 - 3 degrees maybe) so good result. Unfortunately the thermostat and housing didn't turn up in time so I'll shelve those. I have no concerns at all on the current ones.  Then I spent what seemed like 40 days and 40 nights bleeding the air from the cooling system. She also got new air filter, fuel filter and did a Mobil 1 change with oil filter. Hilariously, not an hour after telling my wife how proud I was of myself to be going slowly and meticulously and making sure everything was torqued and nothing missing I went and started it without the oil filter in. The car complained immediately of no pressure and after only a few seconds I turned it off and discovered a shit tonne of oil on the driveway. Sigh. I've driven it since and thankfully doesn't seem to be any problems. AND THEN during the test drive a ratchet extension fell into the battery area in the boot and JAMMED right next to the positive terminal and the car body. Like, just touching it made sparks and it was jammed in there. So, almost killed the engine and then almost burned the car to a crisp. Good start. This was the rails under the splash guards. So stoked, she's straight as and super clean. No rust anywhere. There was a heap of caked dirt that I removed but otherwise looked great. All 4 jacking points are perfect.   Next I want to service the gearbox. Sometimes it's a little reluctant to shift up and I'm hoping a fluid change will sort it. I also have 4 new rear subframe bushes. They're as big as a toddler. I'm renting a tool to help put them in. I can't wait for this because its a bit crashy back there at the moment.
    • Remember when those donkeys kept using freedom units and smashed that satellite to bits on the moon? NASA has their brain switched on and uses the metric system.
