  • 4 weeks later...
LOL did i say something wrong?? =[ I thought N/a cars rely on backpressure for better throttle response and more low end torque? Cause the car is manufactured to run with the back pressure created by the factory exhaust?
LOL just looked at my exhaust and noticed that my car had a butterfly exhaust from factory, hence why i lost power when i put that canon ==' Also did some research and found out that velocity as well as a warm exhaust increase flow and reduces back pressure, thats why proper exhaust systems produces more power than straight pipes. wider pipes = less velocity which = more time for the exhaust gases to escape. Had it wrong this whole time. Made my self look like an idiot across 5 different forums =='
Can anyone tell me if what i just said is true =p
Edited by Deza3000
Back pressure is the term used by the average punter who doesn't know what they are talking about and have just heard other people talking about it.
Back pressure is an unwanted side affect from having an exhaust that has optimum at lower rpm (the rpm where the majority of the population drive at, and for highway speeds). Once you increase the airflow in a restrictive exhaust, so does the back pressure, and the increase in power output slows. If you increase the exhaust size you increase the overall airflow capacity, but at low airflow you lose some of the scavenging effect and can have more turbulent airflow, resulting in lower power output (at low rpm) compared to the smaller exhaust. You would have a higher power output at higher revs though. So there is a trade off.
Exactly this, pisses me off when I hear people talking about it
Spoiler
WHY ELSE WOULD DRAG CARS RUN OPEN HEADERS!!!
Edited by Nikk_666
They are blown though. But still, they put a lot if time into getting the length of those headers right
Not all drag cars with open headers are blown, for example pro stock cars run open headers...
Wut?
Wut?
And wut?
:blink:
Wut?
Wut?
And wut?
:blink:
Judging by your wuts, ive still got it wrong? Im just repeating what i read on a few articles lol.
1. my car does have a butterfly exhaust from factory, theres a valve on the right tip which opens under full throttle, it came factory from nissan. My mates r33 has it as well. Ill take a picture and show you if you want. That canon i used to have was from 2 years ago when all i wanted was noise but then realized it looked stupid and i lost a tonne of power so i chucked it out.
2. The article i read was explaining the dynamics of an exhaust system, it explained how in a straight pipe exhaust, the gases escaping the chamber tend to cool down as the travel through the exhaust pipe causing, the cold exhausts travels at a slower rate than warmer exhausts. I just repeated what it said. Which is probably why expensive exhausts are made of titanium, better conductors of heat.
3, With wider pipes, (im talking like 4inch all the way down) also moves exhaust gases at a slower rate, he used a metaphor describing how water comes out through a hose, a bigger wider hose causes the water to be released slowly while a more smaller hose releases water at a much quicker rate, Its the same principal with exhaust gases. So a straight pipe all the way down wont really perform as well as a proper exhaust. Hypothetically why else would you pay thousands of dollars for a exhaust system if a straight pipe does the exact same thing.
this is my understanding on what ive read about, however you seem to know better so maybe you'd care to explain.
Btw cheers for making me feel like an idiot =)
That butterfly has nothing to do with performance, it's for those who want their car quiet as fark when tootling around but to have a bit of a note to it when they put the foot down.
You sure about that, ive opened the valve manually before, the note does sound much deeper but from what ive seen, in any butterfly exhaust when the valve opens up it does give a bit more performance in the higher rpm. Lower rpm the valve remains closed to increase velocity (quicker flow rate for the exhaust gases to escape) since theirs limited exhaust pulses being released,
http://www.gomog.com...ckpressure.html
The link explained everything pretty well. It also indirectly explains why straight pipes are silly.
Edited by Deza3000
ok, for starters, you can't compare water coming out a hose to an exhaust. there are very much different principles going on (as far as the source of the pressure, and the lack of temp change). there are a few similarities, but also some big differences. water coming out a small hose will have a much higher pressure, meaning that it takes more pressure to move. in an engine, that means more pressure/resistance on the piston trying to force the gases out of the combustion chamber, or slowing down the speed of a turbo.
secondly, the reason they make expensive exhausts out of Ti is because of weight. Ti is a poor conductor of heat compared to mild steel.
you don't get a straight pipe exhaust because you need mufflers and the exhaust has to fit under the car. if you were to have an exhaust that was designed perfectly to accomodate the cooling gas, it would start big and get smaller, but not with steps to make it smaller. it would be like a long extruded cone.
when it comes to headers though, there is many theories on what works, and how they deliver power. you will see ones that are a 4 into 1 design, while others are a 4-2-1 design. this will alter performance, as will the length of the primaries and secondaries.
at the end of the day, discussing the finer details of exhaust design is best left to people who have a decent grasp on the principles (which i don't really class myself as having. i have enough to get me a somewhat decent idea, but am a dunce compared to someone who has studied aero-thermodynamics). it's fine for the average punter to discuss it in a broad discussion as they will often be debating things that will make bugger all difference (like debating the difference between 2.25" and 2.5" on a NA skyline).
TLDR :yes:
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
