1997 Nissan Stagea 260 RS
Pearl White
Rb26 twin turbo goodness with 85,860kms on the clock
4wd attesa and hicas
I have owned the car for about a year now, and in that time it has been a great car, but things change so it has to go.
It is fairly stock with only some light modifications done which include:
Engine:
Splitfire coils
Fujitsubo cat back
eboost-2 8psi (low) 12psi(high)
PWR intercooler (still have original)
Blitz bov (still have original)
Carbon fibre coil cover (still have original) and cam gear cover (not installed)
Exterior:
Nismo smoked side indicators (still have original)
Smoked Dolphin front bar indicators (still have original)
Interior:
Apline folding dvd head deck with navigation, Bluetooth, iPod connectivity
Soundstream components in the front and splits in the rear
Soundstream 4ch amp and mono amp
2x Soundstream 12in subs in box
Nismo gear knob (still have original)
Nismo center gauge cluster (still have original)
When i bought the car the timing belt needed replacing so that was done along with a new water pump.
It has also recently been serviced with new oil, spark plugs, fuel filter, air filter, oil filter
Rego is due in April and if not sold by then the plates GTRWGN are being replaced with standard ones.
Price:
$20000 ono
Contact:
Elliot 0405 418 342 call or txt or pm. If i don't answer when you call leave a msg and ill try to get back to you as fast as possible
https://www.sau.com.au/forums/topic/393992-fs-nissan-autech-stagea-260rs/
  • 3 weeks later...
  • 1 month later...
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
