1997 Nissan Stagea 260 RS
Pearl White
Rb26 twin turbo goodness with 85,860kms on the clock
4wd attesa and hicas
I have owned the car for about a year now, and in that time it has been a great car, but things change so it has to go.
It is fairly stock with only some light modifications done which include:
Engine:
Splitfire coils
Fujitsubo cat back
eboost-2 8psi (low) 12psi(high)
PWR intercooler (still have original)
Blitz bov (still have original)
Carbon fibre coil cover (still have original) and cam gear cover (not installed)
Exterior:
Nismo smoked side indicators (still have original)
Smoked Dolphin front bar indicators (still have original)
Interior:
Apline folding dvd head deck with navigation, Bluetooth, iPod connectivity
Soundstream components in the front and splits in the rear
Soundstream 4ch amp and mono amp
2x Soundstream 12in subs in box
Nismo gear knob (still have original)
Nismo center gauge cluster (still have original)
When i bought the car the timing belt needed replacing so that was done along with a new water pump.
It has also recently been serviced with new oil, spark plugs, fuel filter, air filter, oil filter
Rego is due in April and if not sold by then the plates GTRWGN are being replaced with standard ones.
Price:
$20000 ono
Contact:
Elliot 0405 418 342 call or txt or pm. If i don't answer when you call leave a msg and ill try to get back to you as fast as possible
https://www.sau.com.au/forums/topic/393992-fs-nissan-autech-stagea-260rs/
  • 3 weeks later...
  • 1 month later...
    • This isn't for lotsa powers, and time and effort isn't even a thing I'm concerned about The whole reason is "Just because fun", and "Just because fun" is what I do And whilst there are other kits, with better and more modern turbos (Rev9 use the same Kraken manifold I believe), where in Sydney can I do a drive in drive out with the after sales support that MX5 Mania give My Turbo 86 made around 200kwatw on a AVO turbo kit, and was over 100kg heavier than the MX5, but it was a blast to drive around the streets, until I crashed it.....DOOH, so somewhere around 200 ish level and some whooshy noises and I'll be happy driving to work, the shops, or heading into the country with Jackie for Devonshire tea So, thanks Dose for your info, it sounds like a 0.64 will be fine for what I'm after👍 The only real racing I do nowadays is to the toilet
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
