Hey guys wanting to sell my 1996 gtst manual. need it goone so for a quick sale the price will be $13800 ono. I have owned the car now for nearly 2 years, brought it from a guy in Sydney. who had done all the work to the car. The car made 450 rwhp on 20 psi mods include .
Full exhaust from turbo back with high flow cat
Gt 35 40 turbo externally gated with screamer pipe larger rear housing aswell unsure of size
Stainless steel high mount manifold wrapped in heat wrap
Front mount intercooler
Spitfire coils
Top of engine painted blue
Platinum sparkplugs
Aftermarket plenium
Larger throttle body
Polished Aluminium radiator
Strut brace
Custom fuel rail
700 cc injectors
Apexi power fc with hand controller
Lowered on 19 inch hp rims
Exceedy heavy duty clutch
Tint
In tank fuel pump
Boost gauge
Cd player
I'm sure there is stuff that I've forgot if you guys are interested sms mick on 0413730792 car is also located in Newcastle nsw as I'm using my phone it won't let me upload pics ill send them to you via text until I get some pics up reason for sale is to buy a gtr cheers guys
https://www.sau.com.au/forums/topic/394014-450-rwhp-r33-series-2-for-sale/
Quick update for some things I forgot to put in the mod list
Dual stage boost controller set at 12 and 20 psi
Drift oil catch can
Fuel pressure regulator
Blow off valve ( hidden In front bar)
Pics to come soon guys
thats the engine bay withoput the polished aluminium radiator forgot to metion also heavy duty exceedy cushion button clutchyellow jacket coils not spitfire lol
Edited by SYC-033
  • 1 month later...
  • 1 month later...
  • 2 months later...
  • 3 weeks later...
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
    • If it's reading full rich prior to a misfire that gives one directional hint, if it's already reading lean, etc. If it's reading pretty cleanly stoichiometric then suddenly drops out from a misfire that suggests it's not air mass estimation that's the problem. Could be ignition, could be something more subtle. Could be the CAS has decided to start dropping out at random or the drive pin is worn leading to excessive lash and trigger errors. LTFT can tell you the same but it's slower to react and if this is a recent issue it might not have stabilized. STFT stuck in one direction vs fluctuating back and forth can be used instead but I like to read O2 voltages anyways and interpret directly. If the O2 voltages make no sense in general or are super slow to react it could also be a failing O2 sensor. There's no real error correction for failing O2 sensors in these cars.
