hey folks
Now ive purchased a set of z32 AFM for my r32 GTR - i have the M'S k&n air filter pod and the manifold type things the pods connect to - the stock air flow meters connect up to them perfect, but these z32 air flow meters the 4 bolt holes are near 20mm wider and will not connect to it..
have i been given the wrong AFM's ?
i would assume that they should be the same size as stock, just able to handle greater flow ?? as i was told they are near as good as the nismo spec...
anyone running these AFM's let me know, cause it seems ive been sold the wrong size ? or to suit a different modle/make of car..
The M'S K&N induction the 4 bolt holes on the induction manifolds that hold the pods are the same bolt holes that the stock standard AFM's have. same hole pattern.
But thease z32 AFM's the bolt pattern is near 20mm wider and the AFM themself is much much bigger
any suggestions and/or ideas ??
muchly appreciated
cheers
Guest
