R33 Gtst Cutting Out Intermittently
hey guys i am a second year mechanic and its my girlfriend with the kia rio and just yesterday i cleaned the throttle body and cleaned out the tps and she runs great no stalling no hunting for revs nothing doesn't stall when turning corners or uphill or anything so i would recommend cleaning the tps senor and see how that goes :)
***tps = throttle position senor
also on the subject of misfiring im running 10psi boost and around 4500-5500 my car misfires when im sticking the boot in but when i do it softly it doesn't misfire and i have just replaced the fuel filter and spark plugs so im thinking old fuel pump cant keep up or coil packs any ideas?
I think he did, made no difference. Damn man sounds tough to diagnose. It could be the gearbox, auto gear boxes work in weird ways. I'm still thinking cas, but now thinking about it, it could be the tps... Something you can try is tap a volt meter into your tps, leave the ignition on and open and close the throttle. It should increment nice and smoothly from about .33v to about 4.06v. My car can increment it literally .01v at a time (or .1 can't remember). Don't know how you test the cas but you are having starting, stalling and power issues which could all be related to the cas.
Edited by SargeRX8
Thanks guys.
I cant understand if it's boost related anymore though - you can see from the videos i am under stuff all load and essentially zero boost?
Some of the posts / mechanics opinion is that Coil packs or CAS would be a lot more regular (less intermittent) too. But it feels so similar to wet coilpacks and as you say CAS controls so many things (so does ECU I guess...)
I am also leaning towards heat as a contributer - it may be coincidence - and it does play up when cool (1/3rd temp) but It does seem to be worse at full op temp / hot day / A/C on. Also seems to behave better in the first few kms of driving - usually.
My engine bay feels hotter too if that makes sense. I notice it because I have an unprotected pod so I notice it from a potential heat soak point of view.
Basically I open my bonnet and think "shit that's hot - I should do something about an air box" - and lately I have been thinking shit thats really hot ... (but car is not overheating in any way)
/e boost should be down to about 9pounds now - I gave it another click when I cleaned the AFM - but wasnt too fussed because I seem to be dying on zero boost..
Edited by Sinesweep
Intermittent hesitation when rolling on the throttle, jerks around and surges unexpectedly? Sounds AFM related.
The solder from the afm plug to the pcb inside it lets go after a while (especially after 13+ years of heating/cooling/vibration) and can lose connection when hitting bumps etc. Eg. fine one minute, pain in the ass the next.
I had a very similar problem a while ago and followed this tutorial which completely cured it: http://www.skylinesaustralia.com/forums/topic/113284-fixing-your-rb26-afms/ applies to RB25 AFM as well)
Even if the plug looks fine, solder it anyway while you've got it opened up.
Cheers
Edited by Bitsushiti
Yeah Sarge I don't think the coilpacks are wet I was just looking for a way to describe the cutout.
Will look at the AFM again over the weekend thanks Bitsu.
Today - mechanic drove a bit no issues, I drove home 15kms (nice cool evening) no issues.
3 days to play and see if I can get stranded (I mean locate the problem) or at least a way to "make it occur", or gauge if it is getting worse, or something.
Mechanic and a few other "Office mechanics" are saying "electrical". Should i be considering an auto electrician?
Edited by Sinesweep
Update - more stalling.
In addition to the daily but intermittent cutouts - I have stalled during deceleration a few times (eg slowing for roundabouts / corners etc)
half the time it restarts immediately, the other half it will not. If i let it sit for 2-5 minutes its starts again - and of course runs fine for the ensuing drive.
In frustration I just revved the shit out of it on th elawn after it conked (and restarted immediately) on my driveway.
1st time - hit rev limiter, stalled
2nd time - car only went to 4k rpm (I had foot down) , lost power and stalled.
couple of times i revved to 5 or 6 k and let foot off - stalled
a few times - behaved normally - but on some of those I heard minor backfiring (popping)
getting ready to service it with a jerry can and a cigarrete lighter. ...
Yeah I did.
Just did it again (cap is only on with friction fit old silicon) , and hit up the PCBs and AFM element thingy with some contact cleaner.
Noticed some discoloration that looks like minor corrosion, or solder resist, or something.
I cant access a test AFM, but Im South of Adelaide if anyone has any names of places I could get one, or more advice.
Dunno whether to mess with the Auxiliary Air Control or Throttle position sensor.
Also turned the bleed valve down 2 more clicks whatever that equates to.
photos below
http://i127.photobuc...et/P1000682.jpg
http://i127.photobuc...et/P1000681.jpg
http://i127.photobuc...et/P1000683.jpg
Edited by Sinesweep
  • 2 years later...
Hi Sinesweep, did you end up getting a solution the the intermittent cut out issue you were having? Everything that you described that happen to you is more or less happening to my R33 GTST.
I ended up cleaning the AAC as well as rewetting all the AFM solder joints and the old girl came good.
I'm not sure which (if either) fixed it, but my money is on the AFM dry joints.
Have also since taken out the Boost Tee.
AAC cleaning here - http://www.skylinesaustralia.com/forums/topic/110431-diy-aac-valve-cleaning-idle-reset/?hl=%20aac%20%20clean.
Thanks for the help Sinesweep, I took apart my afm and found that all the solder joints had broken off.
A quick resolder & put it back together, then took it test drive.
Drove like there was never a problem, thanks heaps mate.
Edited by ads47
 Share
    • The two diagrams are equivalent. The R32 one is just one sheet out of about 3 showing everything in the whole car all at once. And without knowing the functionality that occurs in the modules, they are both equally opaque.
    • 8v - 2.48ms 9v - 2.15ms 10v - 1.74ms 11v - 1.41ms 12v - 1.15ms 13v - 0.99ms 14v - 0.89ms 15v - 0.82ms 16v - 0.81ms I'm running these values on my RB20 Neo with 570cc Denso R35 stock jets and it's great. Also bought a set for my Legnum VR4, love these injectors!
    • Thanks for your reply,  Those blue/green wires running to the actuator aren't attached to anything, so I'm not sure how the central locking is still working. I will have to take a good look tomorrow, I don't have the car with me. After googling it seems like a pretty common aftermarket actuator which even uses the same green/blue wires the immobiliser required. i'll test everything tomorrow and if it's working i'll melt the solder, strip it, resolder and neaten it all up with some heat shrink. I don't have to understand it if it works hahaha I just don't want a fire/ short circuit. That R32 diagram looks more like a continuity chart? Can you make sense of this form the R34 manual? 10V is probably due to very flat battery, i'll recheck as well tomorrow, I did have to jump start it haha. Thanks again!
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
