Hey,
I have been stock piling aftermarket parts for a while and once my turbo arrives I'll be pretty much set to put everything in and get it tuned. The car currently has 3" turbo back exhaust (gutted cat), fmic installed which I put on. My jim berry clutch will be going in within a week or 2.
I have nismo 555cc injectors, nismo intank fuel pump, z32 nistuned ecu, z32 afm, metal induction pipe (with stock returns), greddy profec b ebc and the r34 turbo is currently with stao at hypergear getting high flowed.
Im not currently that great with doing work on my car, but I want to learn because i daresay this wont be the last of the mods I do and i actually enjoy working on it.
Just wondering if anyone is willing to help me out with putting a few of the above items in the car before i take it to get it tuned? Im happy to pay you if needed. I know i can get it all put in at the tuners, but i wont be able to see/learn how it is all done by paying them to do it for me.
I realise that if all of those things go in at once, the car will have to be towed which is fine, but even if someone is willing to help me put in the parts that wont affect the cars ability to limp to the tuners thatd be good.
The nistune board should be a straight plug in from what I have been told, as i bought it from Matt at nistune and he said he had worked out a way to do all the modifications necessary inside the ecu rather than have to fiddle with the pins etc. I think he also loaded the r33 base map with the er34 afm on there for me as well.
If anyone is willing to help me out, let me know and ill be happy to remunerate you however you see fit.
https://www.sau.com.au/forums/topic/394039-help-with-installation/
  • Replies 117
Posted Images
Hey Mitch
I'm going to be doing the exact same job as you when my last thing the z32 shows up.
Once mine has been sent of I will have a spare fuel rail that you could chuck your injectors in while you wait
Then you can limp to the tuner and get the fuel rail installed in less time because they wont have to do 1 injector at a time.
Hey Mitch
yeh, thatd be awesome. Did you put your ss1pu turbo in or did you get someone to do it for you?
You could just try to swap ecu's, if the z32 one doesn't work then swap back. But if it does then you could get the turbo on, ecu in, injectors and afm in. do a touch up tune to adjust for the injectors and new afm in nistune and limp it to the tuner. That's what I did in mine...
That is all good in theory and would definently be a preferable option. But to be honest im not confident enough to remove and install a turbo/injectors by myself. I would be ok with changing the afm over except the whole plug wires soldering issue...
I'd be up for giving you a hand but not sure on where as this weather is starting to get crappy.
I've nearly finished the project I have in the shed but still have a few things left!
Let me know when your thinking of starting to see if im available!
Starting?
available!
Well im going to get a shop to put the clutch in because i think thatd just be way too much hassle to try and do on stands in a driveway, plus I don't even know where to begin with doing that. I was thinking it'd be better to do the metal intake and nismo intank pump first as they are meant to be less hassle. They also won't affect the drivability of the car with no ecu tune, because the car is my daily and I don't want it off the road for ages.
Then, try to do the stuff that is going to affect the drivability like turbo injectors and afm as close together as possible and get a tune done more or less ASAP.
Hey mate I won't physically touch your car but I will show you how to do it by telling you what to do?
I have looked at a fair few how to guides on here and they are good, but its not the same as having someone who knows what they are doing with you that you can ask questions etc.
I will be putting my turbo in probably some time this week.
It will be my first time as well so once that's done and if all goes smooth for me I am more then happy to come around and help.
I will just be doing my Turbo
Bashing the guts out of my Cat
and wiring up the Z32 AFM
While im at it I might even chuck my old lowered springs in.
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
