quid pro quo - There;s a few of you guys doing work at the moment so there's obvious benefit to help each other :thumbsup:
Agreed, an it will give me a chance to meet some people from the forums.
Kasko, I'll PM you my number
  • Replies 117
Posted Images
When you say take the turbo off one day, then try put it on 2 days later... What turbo is going on exactly? If you're not sending your turbo away to get highflowed.
I have a freshly high flowed r34 turbo sitting in a box in my bedroom at the moment, because I wanted to try and limit the changeover time as much as possible. So ill have a spare r33 turbo left over at the end. Im not ignorant enough to think that over the easter weekend I could get a turbo high flowed one day and put back on the next if thats what you were thinking...
awesome :)
is it a hypergear OP6 highflow? I'm interested to see the results of one of those...
I may be free on easter too.
Yeh it is, I want to run a safe ish sort of tune to hopefully avoid premature engine death, so I'll probably run no more than about 17 psi.
Going off the hypergear dyno sheets they are good for 260 kw or so but I don't know how much boost that is running. I'll be happy with 240+ though.
I'll PM you my numbeR incase you are interested in having a tinker over the Easter period.
Mitch I think I'll be right to help over Easter
All my house mates and girl friend are heading down the coast but I will be working
So I'll bring some tools around and we can have a crack at it. Maybe if one of the other guys are keen 3 people could knock it over real quick
Yep, sounds good.
I've don't have a heap of tools, so if you wanna bring some so we aren't limited to one of each size socket and spanner that's cool. I also don't think I have a socket or spanner big enough for the banjo's, it's 24mm isn't it?
The only other thing I dont have is the soldering iron for the z32 afm plug, I think it was chucked when my mum decided to clean out the shed...
In regards to the other person, Randon_I_Am (Pat) may or may not be able to help out depending on what he has going on.
Edited by Mitcho_7
ok cool.
Stao from hypergear seems to think that I should be fine reusing the washers and everything from the turbo thats in the car currently, so i think im pretty right for parts etc otherwise.
I have:
z32 and plug.
Nismo 555cc injectors
Nistuned z32 ecu
nismo fuel pump
r34 high flowed turbo and oil feeding line
Turbo/exahsut gasket kit
greddy profec b
metal intake with all joiners and hose clamps
Can you think of any other little parts that I might need ontop of that stuff to get it all in?
How did you go about getting your afm in, i remember you saying something about male and female clips from jaycar?
Edited by Mitcho_7
You'll need the paper gasket for the oil drain flange on the turbo.
Also need 5L of coolant (just get teh cheapest premix bottle you can find)
And a big supply of patience lol
The gasket kit comes with the oil drain gasket
Got heaps of coolant and a little left over oil from my last service...
Anyone know the thread and size of the nuts that go on the bottom two turbo to dump pipe studs, I think I'll get some new ones...
Edited by Mitcho_7
I got in touch with Matt from nistune and he has said that it will be possible to update the afm settings and injector settings so i can limp to the tuners, if I have a consult cable.
Does anyone have a consult cable and have experience with how to change some settings on the nistune software?
Cost me $1413 inc postage for the carbotic version with a new rear main seal and the sleeve pre machined to 14mm. Definently not the cheapest clutch but should hold 350+kw should I ever wish to drop the coin for that sort of power.
I think the organic version is slightly cheaper but has less clamping capacity.
    • Followed ☺️ Assuming those are NEO rods, then at least 400kW all day.
    • Lets keep this going , Spotted this very stock V35 in Penrith and also saw a nice R32 FLY past me on Castlereagh rd , sounded really good.
    • Great work! Give it a clean up with some Emery paper, and I'd run a thread die over the threads too to clean them up. It will make reinstall much easier, and also life easier for the next time it needs to come out.
    • I'm not a fan of high humidity, it's one reason I don't mind being further inland out Ipswich, except the last 3 odd years, the drought broke, and it won't stop raining, which is making the humidity nearly unbearable when the rains are in during summer! For me, my body hates the cold, once the cold sets into my body, I'm totally screwed. I end up with severe muscle spasm in my back/shoulder muscles, and it feels like someone is trying to tear the muscles out. I have no issues with it getting stupid hot, so long as the humidity goes away. So the last 3 years as above, have been woeful! Ha ha. However, June 1st, and I'm only just converting from shorts and a tee, to long pants and a t shirt. And that's mainly as it's a bit wet and miserable and I wanted to work on a car.
    • I much prefer colder weather to hot weather, and especially prefer cold to hot and humid, Goulburn does gets pretty warm in the hotter months, but, I've found the humidity there is not as painful as even Sydney, the humidity up north is to oppressing for this old rooster  In saying this, it does get rather "nippy" in Goulburn for early morning, late in the evening walks, but nothing that a layer or two, some thermal gloves, and a beanie doesn't fix to make it an enjoyable experience, which is much more bearable to me than the oppression of heat and humidity,  especially at night when your trying to sleep If I recall correctly, a "wise man" once said that the "Southern Tablelands" was gods country, and I will not argue that point with him for the fear of a "permaban" LOL In car part related news: My intake is currently in Botany getting processed for the last leg of its shipping journey to my door
