quid pro quo - There;s a few of you guys doing work at the moment so there's obvious benefit to help each other :thumbsup:
Agreed, an it will give me a chance to meet some people from the forums.
Kasko, I'll PM you my number
  • Replies 117
Posted Images
When you say take the turbo off one day, then try put it on 2 days later... What turbo is going on exactly? If you're not sending your turbo away to get highflowed.
I have a freshly high flowed r34 turbo sitting in a box in my bedroom at the moment, because I wanted to try and limit the changeover time as much as possible. So ill have a spare r33 turbo left over at the end. Im not ignorant enough to think that over the easter weekend I could get a turbo high flowed one day and put back on the next if thats what you were thinking...
awesome :)
is it a hypergear OP6 highflow? I'm interested to see the results of one of those...
I may be free on easter too.
Yeh it is, I want to run a safe ish sort of tune to hopefully avoid premature engine death, so I'll probably run no more than about 17 psi.
Going off the hypergear dyno sheets they are good for 260 kw or so but I don't know how much boost that is running. I'll be happy with 240+ though.
I'll PM you my numbeR incase you are interested in having a tinker over the Easter period.
Mitch I think I'll be right to help over Easter
All my house mates and girl friend are heading down the coast but I will be working
So I'll bring some tools around and we can have a crack at it. Maybe if one of the other guys are keen 3 people could knock it over real quick
Yep, sounds good.
I've don't have a heap of tools, so if you wanna bring some so we aren't limited to one of each size socket and spanner that's cool. I also don't think I have a socket or spanner big enough for the banjo's, it's 24mm isn't it?
The only other thing I dont have is the soldering iron for the z32 afm plug, I think it was chucked when my mum decided to clean out the shed...
In regards to the other person, Randon_I_Am (Pat) may or may not be able to help out depending on what he has going on.
Edited by Mitcho_7
ok cool.
Stao from hypergear seems to think that I should be fine reusing the washers and everything from the turbo thats in the car currently, so i think im pretty right for parts etc otherwise.
I have:
z32 and plug.
Nismo 555cc injectors
Nistuned z32 ecu
nismo fuel pump
r34 high flowed turbo and oil feeding line
Turbo/exahsut gasket kit
greddy profec b
metal intake with all joiners and hose clamps
Can you think of any other little parts that I might need ontop of that stuff to get it all in?
How did you go about getting your afm in, i remember you saying something about male and female clips from jaycar?
Edited by Mitcho_7
You'll need the paper gasket for the oil drain flange on the turbo.
Also need 5L of coolant (just get teh cheapest premix bottle you can find)
And a big supply of patience lol
The gasket kit comes with the oil drain gasket
Got heaps of coolant and a little left over oil from my last service...
Anyone know the thread and size of the nuts that go on the bottom two turbo to dump pipe studs, I think I'll get some new ones...
Edited by Mitcho_7
I got in touch with Matt from nistune and he has said that it will be possible to update the afm settings and injector settings so i can limp to the tuners, if I have a consult cable.
Does anyone have a consult cable and have experience with how to change some settings on the nistune software?
Cost me $1413 inc postage for the carbotic version with a new rear main seal and the sleeve pre machined to 14mm. Definently not the cheapest clutch but should hold 350+kw should I ever wish to drop the coin for that sort of power.
I think the organic version is slightly cheaper but has less clamping capacity.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
    • I'll send you a message, but until I know what is OK (and anything that isn't) its kind of hard to work out a fair price. BTW I'm just helping out here, ultimately it is Mel's call what she accepts but I know it will go sooner or later.
