  • Replies 117
Posted Images
The oil feeding line supplied with the turbo looks like its gonna be a bit long, will this matter or should it be trimmed up? If so, how do i got about trimming it, because the fittings on each end dont look like they come off easily...
And just to confirm its a 24mm socket/spanner need for the water line banjo bolts isn't it?
Edited by Mitcho_7
Well after a really long day, turbo is in along with metal intake. At the moment the bov return and bov are bloked off, because I could not get the hose to go on the bung of the intake and the metal bov return pipe without kinking or touching the exhaust manifold. So a trip to enzed on Monday for some rubber hose in the right diameter an hopefully there wont be anything else major crop up.
Hey Mitch I ended up getting some really nice hose that still touches the manifold but is holding up perfectly
Got it from A place on kembla st in fyshwick they are on the right I forget the name of them
The guys at enzed didn't have anything that could handle the heat
Ok, will check it out.
Anyone know why I can now hear a bubbling sound while im driving thats sounds like its coming from in the dash/ under hood?
A shit tonne of coolant came out of the water lines of the turbo, so once they were bolted back up, I poured coolant and water into the top of the radiator. I'm thinking the bubbling has something to do with the way I have done that...
Bleed hole on inlet plenum, 10mm spanner.
Have the car facing uphill and open (release pressure first!)
Bubbles of air trapped in the head come out,
top up from the radiator and see the coolant come out of the hole,
plug it back up,
run the motor for a minute or two,
Repeat untill all air is gone.
Ps. buy good tools, they are good as gold and will last decades, i have some of my grandfathers tools, spanners in the 50'S were made of good steel.
Dont buy shit tools, they will strip bolts and bust your knuckles and you will wish you had just borrowed dads sidchrome set.
also make sure your heater is on when you are bleeding the system as there could be some air in there too. Good tools are worth their weight in gold. I still have all my tools from my apprenticeship except ones that have been 'borrowed' or ones i misused.
Can I assume that if the coolant level in the radiator hasn't dropped between now and when I did this thismorning that most air bubbles are out?
When I first checked it this morning there was a lot less in there than what was put in originally after the turbo install. Im assuming this is because it's a closed system with the bolt ad radiator cap on and all the air that was trapped in the head etc making it seem like the coolant was full but overnight the air has just traveled to the top of the radiator?
got my nistune ecu back today from Matt and exhaust temp light and FICD issues have been sorted!
Also managed to ghetto up a temporary bov return line until the 1 1/8 inch silicone hose turns up then ill use it and wrap the area that touches the exhaust manifold in some heat wrap.
    • That's the thing....the basics of fuel and ignition are deceptively simple.....getting it to behave like factory in all conditions after airflow mods is way more complex. Newer cars like the V37 are all about modifying the standard ECU which is about a billion times more complex than they were 20 years ago, with a bunch of parameters affecting others
    • The larger TB I had on the SS was a pain to get to idle right, but, that was cable In the end they just raised the idle up a couple of hundred RPM so it was happy idling away either in gear or in park (slush box life) I'm curious on how my NC will idle with the new intake, larger TB, and cams that are currently going in/on, but I have faith that MX5 Mania will sort this "electronical" "black magic" out the best they can in the tune with a electronic TB Sometimes I wish I knew more about the intricacies of tuning, but most of the time I don't because I know it would hurt my brain 馃ぃ
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
    • The GTR strut brace clears the new manifold.. by about 0.5mm. So this means I need to buy an OEM GTT Strut brace (again), which will clear the new manifold, but not the bonnet vents. I guess I can sell the GTR Strut brace with the bonnet with the vents as a package deal as someone will need this one day. So my choices are vented bonnet but no strut brace, or GTR Bonnet with OEM brace (which I have to buy) but is bright red instead of the same colour as the rest of the car, which means the entire front end of the car will just be red until it goes back to paint jail. In other news the engine starts and doesn't leak. Why both O2 narrowband sensors think the tune is rich AF I do not know. The idle is also pretty shitty and my expensive IAT sensor from the USA is dead. The car sounds awful. But I assume or at least hope this is due to the many exhaust leaks, and the concrete garage it is in, sitting there with 0 intake bolted to it, and no bonnet or panels or anything to stop the induction/intake sound which is about 200db.
