Hi All,
I was very excited about this new Iphone app called dynolicious. Unfortunately for me I only have an ipad (with some difficulty holding it vertical weged between the center console and some misc items - :) umbrella works well actually) so I used that instead and this is what I got after quite a bit of fooling around and some testing.
settings were: 1450kg , drive train loss 25%, roll-out 1inch (how sensitive is a real drag strip - i.e before it senses your reaction time vs star time), dollout distance (12 inches - default value - is this an unfair start?) (trigger 0.1G)
Car is a stock r34gtt auto - would up the boost to about 14 psi - no other mods.
Is this G of 0.65 accurate - can anybody confirm?
How would a similar car with manual trans perform?
What should I expect from an IC & 3 inch exhaust, should I also do fuel pump and EBC.
My only complaint is that I think the Kw are out of whack, I was expecting around 230kw. Has anybody else tried dynolicous and if so what settings have you used.
I think its pretty much on the money as I did a 14.71 quarter at a real drag strip with the same set-up.
<br class="Apple-interchange-newline">0-10 km/h:0.67 sec0-20 km/h:1.25 sec0-30 km/h:1.82 sec0-40 km/h:2.34 sec0-50 km/h:2.94 sec0-60 km/h:3.57 sec0-70 km/h:4.24 sec0-80 km/h:4.97 sec0-90 km/h:5.73 sec0-100 km/h:6.51 sec0-110 km/h:7.39 sec0-120 km/h:8.49 sec0-130 km/h:9.75 sec0-140 km/h:11.07 sec0-150 km/h:12.47 sec0-160 km/h:14.02 sec
Elapsed Time
60':2.73 [email protected] km/h330':6.59 [email protected] km/h1/8 mi:9.68 [email protected] km/h1000':12.34 [email protected] km/h1/4 mi:14.57 [email protected] km/h<br class="Apple-interchange-newline">
Max Speed:164.0 km/hMax Acceleration:0.65 G'sPeak Horsepower:207 kW<br class="Apple-interchange-newline">
https://www.sau.com.au/forums/topic/394065-anybody-used-dynolicious/
The point was that Dynolicious and similar software is fairly accurate and if there was anyone out there that has used it.
Most of the replies so far strike as either young and immature or just immature.<br class="Apple-interchange-newline">
Your approach to testing the power of your car strikes me as childish. I can go and say, "I dyno'd my car yesterday with my Iphone, got 300kw, fck yeh (self hi 5)"
Or
"Went and got my car dyno'd today at blahblah, car pulled a good 300kw with nice power curve and AFR's, boost was steady, car's looking pretty good"
Which phrase do you prefer?! Or do you prefer peak power reading other than power curve? I know which one wins races.
Edited by eat_me
i think what would be cool is if the car dynod 200kw and the app showed 200kw, i would be impressed. more so if it was consistently accurate against lots of cars. that would be really cool.
but using it to determine how much power your car has, instead of being impressed with what an iphone can do, a liiiiitte silly.
one day im sure this technology will totally be possible. but right now i dont think we should fuss over the very first sign of such a thing :)
P.S. 206kw for your described setup is probably a little overstated. Maybe at the flywheel.
I've got a copy of it but never have really been able to test it properly :(
The app to be accurate needs to be mounted with a good mount, otherwise movement completely throws off the calculation.
One friend claimed reasonable results with it, I'm skeptical.
To actually use it 0-100 or 1/4 mile you need to be in a straight line and start from a dead stop. On freeways you can't exactly stop so I've never done 0-100 properly :)
    • Yep that's a superb price and ther is no way you will over capitalise on you investment.  As to the bracket, again just use the passenger side seat  bracket ( obviously reversed ) as a sample to reshape it and in this case, TIG it back together.
    • Thanks for that.... If only I could do something once and be happy with that, like some people do....
    • I had no transmission at all so I managed to find a big box manual gearbox from an R34 GTT for an insanely good price in EU. I converted it to push type which cost more than the transmission almost, with parts from Amayama! These engines are very strong and can put out decent power with a properly sized turbo. You can save on money from parts like pistons and rods, and invest those in the transmission and other parts. I suggest you join the RB20 Enthusiasts facebook group, plenty of info and almost daily posts there about 20DE/DET/Neo+T builds. (I hope I'm not breaking any forum rules by mentioning third party platforms, just trying to help the buddy out)
    • Yeah, having tried all of those methods including BBQ+recipro/hacksaw, I ended up buying a bush press kit under $150 that works well, like this: https://www.ebay.com.au/itm/355967727167?mkcid=16&mkevt=1&mkrid=705-154756-20017-0&ssspo=sfmmuhxgqhm&sssrc=2047675&ssuid=dJvnaZ11TB-&widget_ver=artemis&media=COPY It basically has a range of pushers and cups with threaded rods between to press out a range of large bushes. The problem with any sawing solution is minimising damage to the subframe side, although it probably needs a quick sand afterwards no matter what solution you try due to damage
    • Hi. Thanks for the answer. I do not have instagram 😄 I too considering turbo the RB20DE NEO 🙂 But i think i upgrade the gearbox first or at least buy new.
