Hi All,
I was very excited about this new Iphone app called dynolicious. Unfortunately for me I only have an ipad (with some difficulty holding it vertical weged between the center console and some misc items - :) umbrella works well actually) so I used that instead and this is what I got after quite a bit of fooling around and some testing.
settings were: 1450kg , drive train loss 25%, roll-out 1inch (how sensitive is a real drag strip - i.e before it senses your reaction time vs star time), dollout distance (12 inches - default value - is this an unfair start?) (trigger 0.1G)
Car is a stock r34gtt auto - would up the boost to about 14 psi - no other mods.
Is this G of 0.65 accurate - can anybody confirm?
How would a similar car with manual trans perform?
What should I expect from an IC & 3 inch exhaust, should I also do fuel pump and EBC.
My only complaint is that I think the Kw are out of whack, I was expecting around 230kw. Has anybody else tried dynolicous and if so what settings have you used.
I think its pretty much on the money as I did a 14.71 quarter at a real drag strip with the same set-up.
<br class="Apple-interchange-newline">0-10 km/h:0.67 sec0-20 km/h:1.25 sec0-30 km/h:1.82 sec0-40 km/h:2.34 sec0-50 km/h:2.94 sec0-60 km/h:3.57 sec0-70 km/h:4.24 sec0-80 km/h:4.97 sec0-90 km/h:5.73 sec0-100 km/h:6.51 sec0-110 km/h:7.39 sec0-120 km/h:8.49 sec0-130 km/h:9.75 sec0-140 km/h:11.07 sec0-150 km/h:12.47 sec0-160 km/h:14.02 sec
Elapsed Time
60':2.73 [email protected] km/h330':6.59 [email protected] km/h1/8 mi:9.68 [email protected] km/h1000':12.34 [email protected] km/h1/4 mi:14.57 [email protected] km/h<br class="Apple-interchange-newline">
Max Speed:164.0 km/hMax Acceleration:0.65 G'sPeak Horsepower:207 kW<br class="Apple-interchange-newline">
https://www.sau.com.au/forums/topic/394065-anybody-used-dynolicious/
The point was that Dynolicious and similar software is fairly accurate and if there was anyone out there that has used it.
Most of the replies so far strike as either young and immature or just immature.<br class="Apple-interchange-newline">
Your approach to testing the power of your car strikes me as childish. I can go and say, "I dyno'd my car yesterday with my Iphone, got 300kw, fck yeh (self hi 5)"
Or
"Went and got my car dyno'd today at blahblah, car pulled a good 300kw with nice power curve and AFR's, boost was steady, car's looking pretty good"
Which phrase do you prefer?! Or do you prefer peak power reading other than power curve? I know which one wins races.
Edited by eat_me
i think what would be cool is if the car dynod 200kw and the app showed 200kw, i would be impressed. more so if it was consistently accurate against lots of cars. that would be really cool.
but using it to determine how much power your car has, instead of being impressed with what an iphone can do, a liiiiitte silly.
one day im sure this technology will totally be possible. but right now i dont think we should fuss over the very first sign of such a thing :)
P.S. 206kw for your described setup is probably a little overstated. Maybe at the flywheel.
I've got a copy of it but never have really been able to test it properly :(
The app to be accurate needs to be mounted with a good mount, otherwise movement completely throws off the calculation.
One friend claimed reasonable results with it, I'm skeptical.
To actually use it 0-100 or 1/4 mile you need to be in a straight line and start from a dead stop. On freeways you can't exactly stop so I've never done 0-100 properly :)
    • If you want to do a single throttle body conversion easily, you won't need to pull anything apart. Take the linkage from your throttle off the linkage controlling the ITBs. Now open the ITBs wide open, and lock the linkages in said position. Now add a single throttle body onto the front of your inlet plenum. No it's not ideal for the last nth of a kw, but it'll be a lot better than what you're already trying to do...   PS, ITBs can be so damn hard to tune from, because roughly 20% movement in a throttle body equates to a change in roughly 80% of its flow (Hence power). When you add up the flow limitations of those small throttle bodys, it is a LOT higher than that of a single large throttle. Hence, TPS is very very sensitive with them, and you do a LOT of work with sensor fusion, and some Maths behind the scenes to make those blends nice, and be smooth.
    • Yep, when Haltech purchased Adaptronic, and all of the Adaptronic staff, including Andy went with it, it took Haltech to the next level. Haltech wanted Adaptronic as they wanted things like Andy's fuel models, and some other IP, AND they wanted Andy too as he is brilliant! Andy has spoken about the incompatibilities between the old 1500 stuff vs Nexxus, and it totally makes sense. It's not JUST software that is different, there is huge changes in the underlying hardware too. It's why Haltech has had soooo many changes in the last couple of years, in terms of Hardware, and Software, and why it has become so damn Amazing. Why do you think guys like Rob Dahm with his quad rotor, went from running Adaptronic's to running Haltechs? Andy. Pretty much, Haltech these days, is Adaptronic, but with more funds behind it, and more staff, and hence Andy's visions, and visions of other people that he helps shape their great visions, into amazing new products. All the new Nexxus gear, whole new software for it, new and better dashboards, the apps that will run on headunits and NOT be slow to respond! I understand people being burnt in the past, but if you're ragging on a company, about products and issues from many years ago, it's more a reflection on yourself, not looking or keeping up with new stuff. In which case, those people should be going back to PowerFC and Nistunes as the ECU's to rave on about...
    • Right, but I thought the problem has been for a while now that even if you know manifold pressure + throttle position you still have non-linearity and aliasing issues vs actual engine load? One way I can see things simplifying is going DBW, then all air going into the engine is represented by the throttle position. As opposed to a random bimetallic strip vaguely linked to engine temperature opening and closing a shutter or some random power steering air valve suddenly allowing a bunch of bypass air. But the same throttle position/RPM at ~atmospheric MAP in different gears is not guaranteed to be same engine load? Honestly, ITBs are of such dubious value IMO. I don't know why these things are hyped up so much. The main benefit as far as I can tell is you reduce the likelihood of cross-cylinder EGR scavenging with significant cam overlap at idle. I would absolutely run speed density and be done with it if not for this fairly esoteric control problem.
    • Hah dont worry, my adult brain has this conversation every single day. Dont waste your money, invest more of it into shares, pay down the mortgage. Then the bedtime insta doom scrolling begins and after being bombarded with gtr's my mind is set: im definitely getting one! I have the current model mx5 as the weekender, but i just miss my boost and literally like your username, the sututu's that come with it. I remember with my 2nd supra, as it had twins and vvti, they used to spool real early, like 1,500rpm so you could just be a spooly boy all day long. Some people say they get over it after a while, not me tho.
    • If you need to refinance your mortgage and reset the loan terms back to 30 years and cash out on your equity for "investment" purposes *cough* car parts, I can help 😊
