Hi fellas,
I have a set of 4 Zumbo F864 deep dish wheels in machine black with a polished lip for sale in 18x8+35 (PCD 5x114.3) comes with genuine centre-caps but with no tires included. Will fit most Japanese cars, Holdens and several European makes.
They look great on any car as it can either bring out the VIP luxury cruiser look or can be fitted to a sports car with wider tires and would then create the performance racer look which was the case when they were on my Nissan R33 GTS-T Skyline.
I bought them for $1,200 several years back and only had them on for a few months before I sold my car so they are in immaculate condition. I am willing to let them go for nearly half this price at $700 ONO so grab a bargain!!
Just want these gone to make room for baby things in my garage as the wife is complaining so please help me out fellas!! :thumbsup:
Wheels located in Footscray VIC 3011 near Highpoint shopping center but can be sent interstate cheaply at buyer's expense.
Edited by Spunky Munky
Wish i saw these before i sold my R34 2 days ago :(.
Would look flush, how did those speakers end up going mate, the ones i sent to you?
Thanks buddy. Yeah, they would look good on any Skyline.
Have not installed them yet buddy. Will PM you when I do. Many thanks. What you drive nowadays?
Any chance you can chuck em on a set of bathroom scales? I'd be interested to know how much they weigh.
Hi buddy, not a problem - I just put them on my scales. They are just over 10kgs each. Say 11kgs to be safe. Please PM me if you are interested.
just pm
Hi matey - have responded.
However, thought I'll post this in the open. They will look great on any Skyline but for the wider GTR's, it is suggest that you run some 20mm spacers as they won't look wide enough.
I am actually selling a set here: http://www.skylinesaustralia.com/forums/topic/394255-quality-20mm-spacers-cheap-for-quick-sale/
Thanks for looking fellas. :thumbsup:
    • You're now in the unrestricted member group so upload away!
    • TBH, it sounds like the threads on the bolt are fubar in a specific section. Most likely as you've been working it back and forth it has torn threads out, as you loosen the bolt, this section enters the nut, now you're spinning a round shaft inside the nut, there's no threads here.   Use something similar to a claw on a hammer that will fit either side of the bolt head and try to apply downward force while also undoing it. The idea is to attempt to catch a thread, or just rip the f**ker out. Caution on ripping out, as it could bend/maime/mangle what the captive nut attaches to. If the captive nut is actually okay, you could do the dirty part of cutting the head off the bolt, then cut a slit in the end of the thread that's now exposed and then screw it up and into the area the captive nut is until it falls out the other side. However, this does risk the remainder of the bolt rusting over time and damaging near the captive nut and also making it rust. However, so can cutting pieces of panel work out to access this area if you don't reseal it properly.
    • Well, every piece of information on that part when you track it back to Nitto says it's for a KIT of theirs. It is also designed thicker to be stronger. And they speak about a specific harmonic balancer bolt they supply for the whole setup.
    • Techniques for removing stuck bolts are: hitting the bolt head with a hammer, heating the bolt to red hot then letting it cool and working it back and forth like you are already doing. AFAIK the idea is to try to crush whatever material is stuck between the threads (and heat also melts locktite but that's almost certainly not relevant in this case).
    • Yuh, I think it works with the Nitto gear only. I presume that you're not also using the Nitto gear? Watch the video. Compare the interface between the Nitto gear and washer (on the gear side) vs the stocker and decide if you think the Nitto gear is different from stock there.
