I bought a set of exhaust system including dump pipe and cat for my R34 GTT. It should be a direct replacement to the factory ones without any modification. Called up a few mechanics and mufflers around the area and got an average quote of $250-$300. I've been told it requires at least 3 hours to fit them on!! Is this reasonable? I looked up online and people saying it should take under 1 hour to replace the whole thing... I got a feeling all the mechanics and mufflers are just try to rip you off...
https://www.sau.com.au/forums/topic/394083-cost-to-fit-exhaust-system/
That's what I thought too. One end of the dump pipe is connected to cat already and the other end just need 5 bolts. Every mechanic I called tells me how hard it is to connect it to the turbo but isn't it as simple as just tighten the 5 bolts? I would have given it a crack myself if I got all the tools :-(
Exhaust bolts are a prick to undo especially off the turbo. You will also want to buy new rubbers because it easier to cut the old ones to revove it. If you feel like you can do it go ahead but make sure you have a good jack and stands as you will be wobbling the car around while fitting. Get some high temp gasket goo to be sure you don't end up with exhaust leaks
i know the feeling... i wenrt and saw my local exhaust guy yesterday about building something custom.......and he flat out told me he doesnt have the time or capable hands to make anything nice like he used to :(
made me a sad panda, hes done some seriously awesome work for my family and our cars over the years
Thanks guys. I just took the car to a mechanic around the area that I didn't call in the morning and he looked at the pipes quoted me $80-$160 for the job which is equivalent to 1-2 hours work which I think at least is reasonable base on your help. He doesn't want me to stay there to watch him and ask me to pick up later. I think he probably just want to take "as long as he wants" and charge me more later... somehow I feel very hard to trust any mechanics.... I will let you know how much in the end.
The hardest part of doing the dump is getting the bolts out in one piece. there very prone to snapping. i have CAT high tensile bolts and anti-sieze on mine so it makes it easy as when i want to take the dump off now
But that's probably why they were saying the dump pipe was hard. if you snap a bolt in there, there's not alot of room to get it out
Your 100% right , mechanics can be full of it, i have gone must be atleast 5 workshops for different jobs and all really let me down,
i just had a dump made up, took them 4 weeks to do it, they didnt event weld in the 02 sensor for me, i drove it away and it was banging and vibrating on the engine, then i took a look under and the whole exhaust is hanging down, no cat bracket on it, hanging off the turbo housing, can you believe that????? and to make it even worse this was done by a respected mechanic/fabricator on here which pisses me off everyday that i think bout it, $1000 spent and im very very dissapointed.:rant: no way im going back to wait what... another 4weeks F#%k off!!
be very very careful who is working on the car and make it clear what you want done and what you expect, thats my lesson learnt.
seems to be alot of cowboys doing work and charging too much.. :mad:
make sure you check what they have done and that its not all hanging low with a shit paper gasket on the dump cause as i learnt , thats not the right gasket and a previous mechanic actually gave that to me to put on along with there shit china dump.
venting... ok all good now.. :thumbsup:
There should be a naming and shaming thread on here :thumbsup:
OK the guy charged me $140 including new bolts and nuts. I still think I got over charged by a little. He actually left the car on jack so I could inspect the work. It seems very straight forward to me. All hangers and connectors fit perfectly to the car there's nothing special you need to do you bolt them on. The pipe that coming out of turbo's waste gate (or engine?) that connects to the front of the dump pipe was not hard to reach at all... especially if you could stand under the car! This is definitely a job around $100 don't get fooled by those untrustworthy mechanics they will just BS their way out and hoping that they could catch a fish...
spot on, they can be like predators waiting for young guys with too much money to throw around, maybe thats the typical stereotype i dont know.
Good to see you got a good job done for a reasonable price, :thumbsup:
@SliverS2 I totally agree. We should have threads here list those "reputable" mechanics that does not try to rob your hard earned money... and those mechanics that try to charge you 3 times of what the job should really cost... Maybe a list for a reasonable price you should expect for different mechanic jobs... :rolleyes:
    • Hi all,   anyone know where I can pick one of these up for a reasonable price? I just resprayed my rear trunk due to fuel stain and my new muse spat install.    added a photo for some content 🤣👍   thanks
    • Consider a 35 too...
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 😃
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
