Walbro 255 Intanks Fuel Pump
By hardsteppa · Posted
Furthermore, to obtain the correct torque value using a torque wrench, use this sort of tool rather than trying to just slip a spanner on there and hoping for the best https://www.ebay.com.au/itm/134997056922?_skw=tie+rod+tool&itmmeta=01JV4F9X0JG2T790PDTYY5XA5C&hash=item1f6e739d9a:g:l1cAAOSw8Q5mBSWf&itmprp=enc%3AAQAKAAAA4FkggFvd1GGDu0w3yXCmi1ehLELIotiBW9ttZY4Avbcw7tIQoAebP9lUKZOfgmr%2FvoyKD0w%2FsryPVoxqpduETEeCq2mpbl1NI5I3OLvNCAR7gYTcWcqn5OW87VWEC3PzWCZel4jW%2FwOjhWx636ZkbVuSY5aaNvIRyIK1rPuGVwUPrsAavS0EEnbtTxkbvwU%2BaS5UeTfkeweMKaNZyIX2ex3QWq7aFVvNsnVwH%2BohFZ09zyW1qu8sjMo6%2F5D5xIDwkMugxXJiBjl4XN2otrl6Q8CGqp6yPZ2eEG5biaKo1p31|tkp%3ABFBMxtCnj9ll -
Confirmed, the block was checked for cracks and was found healthy.
Let's keep it concise please; the fellow asked for help, not nonsense terms. R33 steering overhaul torque values are shown here. -
I shouldve mentioned that the engine is near being complete. I double checked with my mechanic but im pretty sure the machine shop did all the nessecary checks on the block. i also won’t be driving on 800 all the doing doong pulls. Mainly be driving and cruising with friends on low boost maps occasionally opening everything it’s got.
Should be close enough. Noting that 88Nm is equivalent to 2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there.
