From my readings it is recommended to block off the middle and restrict the rear orifice on a rb25/30 using vct.
Now what would happen if you blocked the rear and restricted the middle???
brief specs are as follows
standard oil pump
1.5mm restriction (in middle)
crank case breather on intake side of sump above oil pick up
from my understanding as the front only feeds the vct module, by blocking the rear wouldnt that give better oil distribution and balance in the head???
How many orifices does the rb26 have and where are they located in comparison to the rb25 block. ive read they have one blocked off standard so im assuming they have 2, and for better balance the middle would be blocked- makes sense
26s have 2. 25s have 2 head feeds in the same spot and a completely seperate vct feed at the front. you can block/restrict either of the 2 main feeds afaik, it shouldnt make any difference. but if you wanna be picky i would have thought blocking the rear and using the middle would be best for even pressure.
both factory 26s I've opened have had one with a 2mm restrictor and one blocked off
Righto, thanks for that.
So you think there will be a significant pressure difference in the head?
What can this result in? Oil starvation to rear of head/cams?
Restrictors reduce flow not pressure. I have 2 x 1mm restrictors (and sump breathers) and hydraulic lifters work fine. So far no oil from cam covers into catch can v vast amounts with 1.5 restrictors and no breathers.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
