Varrstoen 2.2.2 On R34 Gt-T?
Hi Guys,
Just wondering if anyone can help me out..
I have recently purchased a 2000 R34 GT-T coupe and I am looking at purchasing a set of Varrstoen wheels as a real set of TE37's is a little out of my price range at the moment.
I am looking at getting 19 x 9.5 all round with the +12 offset..
Will I have any dramas fitting these on my car??
Any info would be greatly appreciated
Cheers
I
Thanks guys
Allot of people seem to have diff opinions and ideas..
Yes the +12 is very tough looking.. But because I want 19"s not 18"s i think I might get into trouble with the guards as I dont want to have to have them rolled or anything..
Think +22 might be the safest.. Thats what varrsteon have recommended.. Im really not sure haha
There are too many options haha it can get quite confusing
Yeah you are probably right... I was trying to avoid it but yeah if it comes down to it il just have them rolled i guess..
Is your r33 the morone coloured one with the carbon spoiler and Varrestoens??
I reckon +12 gives it a much tougher stance
+22 will make it flush with the guards and +12 will give it a bit of poke
depends on what look you want
Would love to see shots of the front.
I just bought a set of Varrstoen 3.3.2 in Satin black in 19x9.5 +12
No tyres yet, but it seems like there will be a little guard work to fit them.
jah :)
What rims? Are these Varrosteons/Rota's or?
they look like rota's
here are the fronts
18x9.5 +20
don't mind the multi coloured panels haha getting it sprayed in white soon
Edited by shinobi_s14
Nice photo by the way.. Looks awesome :thumbsup:
Thanks man
Looks nice. Got any more pics?
Yeah rota grid r's
shinobi_s14
was that the front bar owgasm was selling?
Nah man, but I did get the rear bar off him :)
 Share
    • The two diagrams are equivalent. The R32 one is just one sheet out of about 3 showing everything in the whole car all at once. And without knowing the functionality that occurs in the modules, they are both equally opaque.
    • 8v - 2.48ms 9v - 2.15ms 10v - 1.74ms 11v - 1.41ms 12v - 1.15ms 13v - 0.99ms 14v - 0.89ms 15v - 0.82ms 16v - 0.81ms I'm running these values on my RB20 Neo with 570cc Denso R35 stock jets and it's great. Also bought a set for my Legnum VR4, love these injectors!
    • Thanks for your reply,  Those blue/green wires running to the actuator aren't attached to anything, so I'm not sure how the central locking is still working. I will have to take a good look tomorrow, I don't have the car with me. After googling it seems like a pretty common aftermarket actuator which even uses the same green/blue wires the immobiliser required. i'll test everything tomorrow and if it's working i'll melt the solder, strip it, resolder and neaten it all up with some heat shrink. I don't have to understand it if it works hahaha I just don't want a fire/ short circuit. That R32 diagram looks more like a continuity chart? Can you make sense of this form the R34 manual? 10V is probably due to very flat battery, i'll recheck as well tomorrow, I did have to jump start it haha. Thanks again!
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
