Hi,
Thought I'd start clearing out the garage. I have a set of Nissan rims. Someone might be able to tell me what there off. Pretty sure it's a skyline. Anyways they are in good condition and I need them gone ASAP.
$100 in Mentone
ps. Rims need to be cleaned. Will come up a treat when they are polished
Edited?
I posted something then edited it mate, I thought they were from something but after googling I was wrong.
Free bump
Free bump
Haha. Yeah no worries mate. Thanks for the free bump.
