Is the tacho in the S13 reading correctly? Sounds like the ECU is hitting it's rev limiter (constant miss noise you mention). Maybe get another stock or an after market tacho and see what it reads? Something like an SAFC NEO or Greddy Infometer will also do the trick - see what the ECU is seeing.
old mate of mine had this problem when we put a 25 into his s14, would just rev up then bog down/ pop/ lose power.. definitely was NOT LIMITER..
We tried another r33 ecu which we knew worked properly, and in the s14 the problem was still there.
he had the loom checked and was all ok, so only thing that never got checked was sensors on the engine
still has the problem now, keen to know if u find out the cause..
EDIT: just remembered something , if u backed up right before limiter and got on the gas again it would hit limiter normally... does urs do the same?
DOUBLE EDIT: WTF HAPPENED TO MY EDIT HAHAHAHA
Edited by BrynDETT
don't get why half the ppl on this forum give sarcastic/ useless information just because they think the topic is not worthy...
think some ppl need to need to shut up when they have nothing to say, instead of trying to get their post count up...
end rant
OP might not know wat rpms he is reaching because the s13 tacho will read 1/3 out... the needle simply goes past the gauge..
it doesnt matter what rpm its reaching, its still not working properly
it is pretty critical actually to know what rpm it's reaching.
the op needs to include more relevant facts if the interwebz is going to solve the issue.
otherwise take it to a real life shop with a mechanic man who can diagnose accurately from seeing the car and how the motor is running, and fix.
you can't just say "it's missing and sounds weird, please diagnose".
Edited by Ronin 09
Does fitting a 6-cylinder engine into what is normally a 4-cylinder car involve anything that faintly resembles an adjustment to the tacho so that it now calculates for a 6-spark cycle instead of a 4-spark cycle?
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
