hi guys.
on the way home today i notice my dash cluster was acting odd. the tempture gauge and tacho where jumping around and the speedo was "stepping" and not smooth (probly not accurate too).
had a sticky beak and didnt see any thing odd.....
when the car is on turbo timer the tacho and temp start jumping around.
any ideas?? cause i'm miffed! i'm thinking cluster is dying?
cheers
https://www.sau.com.au/forums/topic/394150-jumping-m35-dash/
hrmmm new problem this morning,
now the 4wd light,abs, hand break light where flashing on and still the same problems as before, also the power steering is really heavy???
thanks 4 the offer ryan, brother inlaw works @ just jap sydney (also where the car came from), so he is going to help with a cluster hopefully, but after this morning i'm starting to think it might not be the cluster, might be a battery/alternator/alarm wiring issue or something totally different :/
had a similar thing happen inmy bomb-a-dore, went into limp homee mode or something, turned out the alternator was frried......
took it to brother inlaw, and it pulled a 1000 fault code, something about the battery or connection.
but the battery volt is fine, but also its the stock battery probly on the way out.....
o well all is good now big difference from yesterday and this morning
I think U1000 is grounding points- check in the battery box, and some locations under the dash have grounds onto the steering rack- I bet that s close to your problem. Also the grounds in the engine bay. Search google, and you'll find a service bulletin about it.
And the most obvious thing is to change the battery before chasing more obscure causes. Even though the voltage may look OK, I've seen funny stuff happen.
My M35 battery problem showed up when the car began opening the tailgate by itself. Then it moved onto weird flashing lights on the dash before the usual not starting the car when I turned the key. It may not be a bad battery, but it's real easy to change & thus rule out as the cause.
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
    • I have information on this for anyone that comes looking again. https://www.facebook.com/share/p/18gsbFaYTU/ The rb25det neo from the stagea has the same sumo as rb26 and r32 gts4 (and other awd models). The sump that has caused so many problems during swaps are from the awd neo Gloria's. The casting numbers on the block and oil pans are different so this may help identify if you can't confirm where the motor came from
    • Not feasible to fix the boot lid you had? Damage looked minor/hard to even see :p Source: Drove into something recently and you should be happy you didn't!
    • Another new used boot arrived at the painters, it was sent back as there was nearly as much damage as the original one I want to replace  Finding a clean used boot lid is proving problematic, and I'm not keen on dropping $1500 on a new one from Mazda Sigh....
