hi guys.
on the way home today i notice my dash cluster was acting odd. the tempture gauge and tacho where jumping around and the speedo was "stepping" and not smooth (probly not accurate too).
had a sticky beak and didnt see any thing odd.....
when the car is on turbo timer the tacho and temp start jumping around.
any ideas?? cause i'm miffed! i'm thinking cluster is dying?
cheers
https://www.sau.com.au/forums/topic/394150-jumping-m35-dash/
hrmmm new problem this morning,
now the 4wd light,abs, hand break light where flashing on and still the same problems as before, also the power steering is really heavy???
thanks 4 the offer ryan, brother inlaw works @ just jap sydney (also where the car came from), so he is going to help with a cluster hopefully, but after this morning i'm starting to think it might not be the cluster, might be a battery/alternator/alarm wiring issue or something totally different :/
had a similar thing happen inmy bomb-a-dore, went into limp homee mode or something, turned out the alternator was frried......
took it to brother inlaw, and it pulled a 1000 fault code, something about the battery or connection.
but the battery volt is fine, but also its the stock battery probly on the way out.....
o well all is good now big difference from yesterday and this morning
I think U1000 is grounding points- check in the battery box, and some locations under the dash have grounds onto the steering rack- I bet that s close to your problem. Also the grounds in the engine bay. Search google, and you'll find a service bulletin about it.
And the most obvious thing is to change the battery before chasing more obscure causes. Even though the voltage may look OK, I've seen funny stuff happen.
My M35 battery problem showed up when the car began opening the tailgate by itself. Then it moved onto weird flashing lights on the dash before the usual not starting the car when I turned the key. It may not be a bad battery, but it's real easy to change & thus rule out as the cause.
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
