I know its been asked alot but im new to the RB25/30 turbo'd thing.. i just got a RB25 R33 GTS-T head and buildind a RB30 bottom end im aiming for 320+rwkw (435rwhp+) any advice welcome on anything more info the better my mate and i goin to build it!!
cheers oscar
Edited by MRHD66
https://www.sau.com.au/forums/topic/394156-rb2530-help/
in before it's closed, try searching and read what has already been written.
what do you need to know, 320rwkws is easy for a 25/30, fordged piston and rods, cams, injectors and the correct turbo and then keep winding in boost till you get what you want :thumbsup:
or buy a rb26 a pair of -5s, poncams, 700cc injectors and a rb30 sump
https://www.sau.com.au/forums/topic/394156-rb2530-help/#findComment-6266891
HD holden, gold, I was at oran park one day with the BSM guys ( GTR race team ) and heard a nice sounding rb pull in stuck my head out the door and no other skylines anywhere, but a very clean EH wagon with a older gentle man climbing out of it,after a quick chat it turns out he put a full GTR driveline in it with 300wkw
https://www.sau.com.au/forums/topic/394156-rb2530-help/#findComment-6266950
Thread closed. Believe it or not, but since SAU started more than 7 years ago, this topic has been discussed before.
Please use the search function in future. It may be found here:
http://www.skylinesaustralia.com/forums/index.php?app=core&module=search&search_in=forums
While we understand that it can be frustrating to have your thread closed - Please consider that other members may feel it to be disrespectful and selfish of you to post a simple question, without using the search feature to review the wealth of information provided by said members over the years.
If you still feel that this action is unjust, then please PM me and we can discuss it further.
https://www.sau.com.au/forums/topic/394156-rb2530-help/#findComment-6267397
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
