either do a full engine, rear end, everything swap like i did (if you really love your car) or just sell and buy a turbo model
pm me if you want a list of parts and aproximate prices of what i payed about 3 years ago
Well, i bought the car for a very low price so even if it costs me $3000 to get the turbo in i still get a turbo r33 for less than the average selling price...
Have you read what most of the people have been saying here? The rb25de engine runs much higher compression than the rb25det, this means if you bolt a turbo onto it it will more than likely ping due to the boost and high compression. It will cost more like $5k (to buy a rb25det and then install it) to do the conversion, plus you still need to change the brakes (well you dont have to but I would as the gts25-t came with better brakes than the gts25). Next you'll be asking about doing an auto to manual conversion... *laugh*
If you're willing to accept any possible misadventure go for it...I've been more than happy with my bolt-on....high-compression can be your friend if tuned right.
It's also true..the R33 N/A brakes are very ordinary 4-stud items...the R34 N/A are 5 stud with twin piston fronts instead of single, you also have vastly different cams to the turbo model.
Check out the N/A section..it's been covered a fair bit
haha i knew it davor!
just stick with what you have got mate, its still a bloody good car. and you just bought it like 1 month ago! and you are on your P's and its illegal to drive an R33GTS-T (if you do and crash it you may not be covered by insurance...)
just learn how to drive in this car properly and later on go and get more power...
Waz.
There is plenty of information that can be found via a search on here.
But basically not worth doing. Cheaper, and more effective to sell off your old N/a (maybe get $1500 for it), and get an RB25DET (maybe $2500 for one).. and swap the whole engine over.
If you did turbo it, due to different compression, etc you would only be able to run fairly low boost levels (7psi or so). It would work, but if you got that far, you'd probably want to modify it, and then you may as well have got the RB25DET put in instead.
plus an engineers certificate
Are you sure about that? I thought you could self-engineer an engine swap if it was an engine present in the model range.
Edit: Here we go... from http://www.rta.nsw.gov.au/heavyvehicles/do...s/vsi/vsi06.pdf, hence NSW only:
Examples of minor (owner certified) modifications are:
• engine changes where the capacity increase is less than 15% above the maximum size engine available for the vehicle (providing no major structural modifications are necessary and where noise and/or exhaust emission ADRs apply, all standard equipment such as carburettors, exhaust systems, exhaust gas recirculating valves, oxygen sensors and catalytic convertors relating to noise and emission control are retained and operate correctly);
• the fitting of a proprietary sunroof (if the modifications are of a minor nature only);
• fitting a “package” available as optional equipment for the vehicle (eg front disc brakes, power steering, alternative transmission and bucket or bench seats);
• additional lighting eg: fog & driving lights;
• alternative wheels and tyres within the owner certified limits set by the Authority (see Vehicle Standards Information Sheet No. 9 Guidelines for Alternative Wheels & Tyres);
• fitting of handling enhancing suspension components such as roll stabiliser bars and up-rated shock absorbers.
LW.
Waz.
It waz for future reference... to see if it would be better to buy a turbo or to get a conversion!
oh well... i'll have to wait a few more years...
    • Those brackets are known for snapping. Easy to fix the metal, and a good seat reupholsterer can fix the rest. I'd potentially get them to look at making new foam too. Even if you've got the old, it will be partly compressed / not as supportive as it should be.
    • Yep that's a superb price and ther is no way you will over capitalise on you investment.  As to the bracket, again just use the passenger side seat  bracket ( obviously reversed ) as a sample to reshape it and in this case, TIG it back together.
    • Thanks for that.... If only I could do something once and be happy with that, like some people do....
    • I had no transmission at all so I managed to find a big box manual gearbox from an R34 GTT for an insanely good price in EU. I converted it to push type which cost more than the transmission almost, with parts from Amayama! These engines are very strong and can put out decent power with a properly sized turbo. You can save on money from parts like pistons and rods, and invest those in the transmission and other parts. I suggest you join the RB20 Enthusiasts facebook group, plenty of info and almost daily posts there about 20DE/DET/Neo+T builds. (I hope I'm not breaking any forum rules by mentioning third party platforms, just trying to help the buddy out)
