Gday All, got my cefiro up and running with a few mods(car was bought minus motor and box). It seems to go ok by the seat of my pants
but after a short drive I pulled my plugs to check the gap (0.8mm)and this is what they look like.
It is already booked in for a dyno this week but the shop is 1/2 an hour away-is this safe to drive that far?
Mods:
Bosch 044 fuel pump
GTR injectors-clean and tested ok
Z32 AFM
GT2871 turbo
FMIC
3 inch turbo back exhaust
ECU remap-tuner has checked and confirmed against his other files that its correct for my mods.
thanks for any help
Jes
https://www.sau.com.au/forums/topic/394194-is-this-lean/
Yeah these are copper plugs, I didnt know whether to go 6 or 7 heat series as there are tons of guys doing both,
my tuner said 6 so I did that. what would the difference be with a 7 plug?
Jes
it's just a safe measure, 7 will stay cooler when the engine is running above standard measures. Lower the risk of pre ignition. Repco should have them, super shit won't.
Edited by SargeRX8
https://www.sau.com.au/forums/topic/394194-is-this-lean/#findComment-6268006
Its very hard to tell lean and rich from plugs when you are running fuel with no lead in it.
What I can tell you is that your cylinder temps are too cold for that plug or your plug is too cold for your cylinder temps.
The white porcelain of the plug should be clean and white much further up the plug than where it is.
You could run a 5 in your engine, or lean it out to up your cylinder temps.
https://www.sau.com.au/forums/topic/394194-is-this-lean/#findComment-6268028
His op said, new plugs out after a short drive. I really doubt that short drive is substantial time to darken the porcelain...
https://www.sau.com.au/forums/topic/394194-is-this-lean/#findComment-6268667
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
