Does anyone else have this problem with there doors are really easy to close yet everytime I have a passenger get out of my car they SLAM the F#%KING DOOR?
This wouldn't bother me to much if the window had a frame but it doesn't and i cringe thinking the glass is going to break.
Is this just me and my car??
https://www.sau.com.au/forums/topic/394204-slamming-doors/
I don't even have to push my door to close it. I just get out my car and quickly move out the way while the door shuts itself. I like to think its an automatic door closing feature. Honestly only need to push the door closed when there is a strong wind in the wrong direction.
I'd never see a reason to slam the door, but I see it happen and it makes me want to cry.
https://www.sau.com.au/forums/topic/394204-slamming-doors/#findComment-6268007
Bahaha i'm the same. Heavy arse doors close by themselves with the slightest of touches, yet every goon that jumps in/out BOOM!
https://www.sau.com.au/forums/topic/394204-slamming-doors/#findComment-6268127
try having a boot with stuffed struts. the amount of times i warn people yet they still drop it from the highest possible position is annoying to say the least
Edited by drunkn snail
https://www.sau.com.au/forums/topic/394204-slamming-doors/#findComment-6268141
People that slam doors are usually one or more of the following:
- Don't have a car
- Cannot afford a car
- Don't know anything about cars
- Have a car with rooted doors, so they slam doors out of habit
- Generally people that talk BS
- Generally rough with anything they hold.
- Usually messy
https://www.sau.com.au/forums/topic/394204-slamming-doors/#findComment-6268163
I had to lol at this. I do the EXACT same thing when I get out of my V.
1. Swing door open with a flick.
2. Step out of the car like a boss.
3. Door perfectly closes by itself as I walk away.
https://www.sau.com.au/forums/topic/394204-slamming-doors/#findComment-6268231
- Don't have a car
- Usually messy
So true!! Thats the guy who slammed my door today hence the start of this thread.
He's my room mate and a clown.
CAN YOU HEAR ME DAMIEN?? YOUR A CLOWN!!!!!
https://www.sau.com.au/forums/topic/394204-slamming-doors/#findComment-6268273
- Don't have a car
- Usually messy
hahahahaha oh shit that made me laugh
I got so many bruises from cleaning car and having the door slam on me, but yeah i make friends believe i have auto closing doors, funny as!
Edited by R6n350GT
https://www.sau.com.au/forums/topic/394204-slamming-doors/#findComment-6268506
Some one needs to develop the soft closing hinges like they have on cabinet doors. You know the ones where it doesn't matter how hard you try slam the door/drawer it always stops an inch before closed and continues the rest of the distance slowly & softly.
https://www.sau.com.au/forums/topic/394204-slamming-doors/#findComment-6268704
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
