  • Replies 100
not seperating sorry bud
silicon intake pipe has with metal ring section so cant close in on itself (from afm to turbo with inlets for factory bits) $50
RB25 5 Speed Gearbox (120Km's) $1400o.n.o
$320 for front brakes
$300 for mint bonnet
$60 per gaurd
$60 per bare door
$80 r33 driveshaft
$50 S14 driveshaft
S2 aircon pump $50
S2 aircon condensor with lines $50
Carpet $50
Passenger window $30
Passenger lock/locking motor $30
Brake Booster/Master $80
Clutch Master $40
Pedals $80
Steering Rack $80
LCA's $80
MAY TAKE PART TRADE FOR PARTS for my track car, like aftermarket rb25 items, gauges, harness's, gt wing, race seats etc etc
im also chasing S14a front bar reo and windscreen
Throw me offers
pm sent
PRICES UPDATED NEED STUFF OUT THE WAT ASAP
silicon intake pipe has with metal ring section so cant close in on itself (from afm to turbo with inlets for factory bits) $40
RB25 5 Speed Gearbox (120Km's) $1250o.n.o
$300 for front brakes
S2 AFM with plug $80 (will trade up for Z32 with plug)
$250 for mint bonnet
Seatbelts COMPLETE set $60
2x climate control units $30 each
$50 per gaurd
$50 per bare door
$80 r33 driveshaft
$50 S14 driveshaft
$100 33 half shafts
$80 airbag steering wheel
$100 ignition/door locks with single key
S2 aircon pump $50
Carpet $50
Brake Booster/Master $60
Clutch Master $40
Pedals $80
Steering Rack $80
2x pair LCA's $50
stock rear arms $20 pair
SHELL with rear window, rear quarter windows, body loom, front end is dead straight should be rolling etc $500
COME DOWN THROW CASH AT ME AND TAKE STUFF :P
0417080960 please DONT call just MSG thanks
bump bump few lowball offers on the 25 box there were so many ppl after the box now they all dissapear wtf????
throw offers on any bits guys need this stuff gone so shell can go and the s14 can be back in its garage :P
Bump bump!!
Front brakes $280
Bonnet $240
Gaurds $40 each
Carpet $40
Air bag wheel $80
Pass air bag $60
Stock diff and half shafts $180
Heaps of bits left, enginge and box out this weekend then a quick strip and shell will go :)
S2 AFM with plug $70 (will trade up for Z32 with plug)
$240 for mint bonnet
Seatbelts COMPLETE set $50
$40 per gaurd
$40 per bare door
$80 r33 driveshaft
$50 S14 driveshaft
$80 33 half shafts
$80 ignition/door locks with single key
S2 aircon pump $50
Carpet $40
Brake Booster/Master $50
Clutch Master $40
Pedals $80
Steering Rack $70
2x pair LCA's $40
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
