hey guys,
i changed the oil in my r33 gts-t today, i used Motul 10w-40 Technosynthese as i was instructed to do so by the guy who has a 180sx at autobarn today. 10w-40 seems to be the right content as ive doen my homwork on the net and people say the same thing. So i changed it no worries, and the filter, and now the eninge makes a ticking noise??? is this normal? didnt happen before this, and if it did no where near as loud...can someone help?
https://www.sau.com.au/forums/topic/394264-changed-oil-now-making-noise/
People at autobarn and super cheap auto always recommend thin oil as thin oil is generally more expensive and because its mean to "better", 10w-40 is used when the car is new and can be used for years until the engine starts seeing internal engine wear which means you need to slightly up the grade of the oil for better protection for your engine.
R33's are getting old 16/ 17 / 18/ 19 yrs old and there is quite a few of them out there that aren't displaying the genuine kms
With engine oil allot of people make the silly mistake of worrying about what brand of oil in there ie motul royal purple etc and not worry about the most important thing which is matching up the right oil grade for your engine and application.
i would use a 15w - 50 or 15w 60,
Its a little thicker on start up which will cut out your ticking and the engine will sound smoother overall , when the cars at normal operating temp, the oil will be a little thicker so you will have better protection. Great for if you give the car a beating and it wont blow as much smoke when hitting boost.
If the sound doesn't go away, probably lifter additives would have been used before to cut the sound out.
Edited by G4orce
What if you rebuild your engine, do you have to go to a thicker grade as well? I rebuilded my engine 2 years ago and i'm using 10-30 mobil 1. Dont have no thicking sound or anything and oil pressure seems to be good. But people keep telling me to go something thicker but i'm not sure if i should.
You DO NOT want to be using a 15w oil. This is the viscosity behaviour at cold startup. You want a thin oil to get through all the oil galleries quickly, so you should be using a 5w or maybe 10w.
The noise could be any number of things - sticking lifter, injector noise, piston slap, big ends.
Pretty sure that is worn hydraulic lifters, have heard that in cars with high km's, but its usually just for 10-20seconds
ive been using 0-40 mobil 1 and i reckon its perfect , wont change unless it starts using oil
Most of these replies presume the OP's noise is worn bigends, so more info is needed.
My thoughts are the new oil has dislodged some gunk and now he's got a sticky lifter.
OP needs to get his noise diagnosed correctly, perhaps post a u-tube so we can hear it.
Wha? Not a single reply suggests it's big ends.
As has been said, previously and by you, it's likely lifter noise which was being muffled by thicker oil. It's not a big deal. You can either ignore it or go slightly thicker next time or, of course, get your lifters cleaned/replaced.
You shouldn't go to a thicker oil just to mask a proplem that should be dealt with properly. If it is the lifters you should have them pulled out and cleaned or buy new aftermarket ones. A thicker oil will ensure your bottom end wears out quicker on cold starts unless you wait for it to warm up before you even think about leaving your driveway.
contact the people that built the engine and ask THEM what they built the engine for
depends what you use the car for. if you are doing heavy track work and you need/want an oil that is a 60w, there is really no option that will give you a cold 5w. personally I use edge 10w60 these days
Even 5w-30 is too thick. True story. Bobistheoilguy.com
You should read bobistheoilguy.com
hell if you wanna pour oil into your RB every time you turn the key, be my guest... remember the bottom end design of the RB motor is from the 80's when 20w50 was a standard viscosity, not form 2008 when motors are actually built for 5w30.
also you need to be more specific with the bitog reference... just saying to go to the site doesn't really help people
    • I agree re not trusting it as it makes mistakes however can do hours of research for you at times by simply asking a question
    • The I've done a lot of research and feel like I'm becoming a nut and washer expert. The washer in question doesn’t look very conical—it’s almost flat, but one side has a chamfer. The guide's picture shows the convex side (chamfered side) facing the nut, but the text says the chamfer should face the pulley, which is confusing. If I follow the picture, the chamfer faces the nut, but the instructions say the opposite. When I place the washer on a flat surface, one side looks flatter—maybe that's the concave side—so I would expect the chamfer to be on that side. But it isn’t, which adds to the confusion. The term chamfer is also throwing me off. I always thought the concave side should face the pulley, and the convex side (with the chamfer) should face the nut or bolt head. But Nissan’s instructions say the chamfer should face the pulley, which seems backward. I know I’m probably overthinking it, but I want to be sure I’m doing it right. Also, I’ve seen some people replace the nut and stud with a bolt, but I assume that’s not a good idea, since it might not keep proper tension on the tensioner. Lastly, just to be 100% sure: the pressure washer should face the pulley, then the conical washer? That feels strange, since usually the pressure washer goes first, facing the bolt or nut.
    • I checked, i dont think it was the indicator stalk. The problem just magically fixed itself though.
    • H1 is not the Humvee, but is the most road based version. Lachlan (HankScorpio) on here has a proper Humvee. He imported it a few years back.
    • Welcome Thomas! Sounds like you've made some progress. Are you able to drive it and enjoy it a bit now ?
