F/I kits for under 10k in Aus, try and find one from a dealer in aus that well sell it for under 10k, the HKS SC kit i was quoted 15k for the kit and install from a shop in sydney, cant find any dealers that have any sort of kits for turbo conversions, all parts have to be sourced from the USA it seems.
  • Replies 49
Yea better off importing it yourself, seen the HKS SC kit around 6-7k on Nengun?
http://www.nengun.com/hks/gt-supercharger
I got a flare with my car as well. What I really haven't seen is a "quake grab bag". Apparently, some cars have bags filled with high-energy biscuits just in case you get stuck in your car during an earthquake.
Oh FFS.
Can't let this go on. ETC and a Flare are NOT rare options- k?
http://nissan.epc-data.com/skyline/cpv35/6827-vq35de/misc/
Here is the list of factory options. You can figure out if they are rare or not. I would say the Feather duster, and life hammer would be a start at getting rare.
I have Factory Remote control engine starter.
k - go.
Oh FFS.
http://nissan.epc-da...27-vq35de/misc/
k - go.
that may be true. but last i heard that flares are ment to be removed as part of compliance. so for them to still be in the cars when they are registered here in AU. its quite a rare thing.
same thing with the ETC, alot of Japanese people keep their ETC to use on their next car.
Yes, Flares are suppose to be removed for compliance. But they are fitted to every freaking Jap car- hardly what you'd call a "rare V-series" part. ETC is built into most of these cars too, and most cars in Japan.
So who has KF20A0 = Front Camera? I know of one PNM35 Stagea with them on the way over from J land.tongue.gif
Oh FFS.
k - go.
Hahahhahah CALM DOWN !!!
They are actually rare to see in a V after compliance so I can't agree with u there .... But what I can sort of agree with is I think we are a bit off topic as I wouldn't call the ETC or a flare parts ? :domokun:
Watch out, or I might have to teach you a lesson with my rare optioned feather duster...laugh.gif (so wish I had one.)
Not getting worked up, just want some actual progress on V's with cool parts not- I haz a flare... cool bro, I haz flare toono.gif
http://www.skylinesaustralia.com/forums/topic/293993-m35-stagea-sales-brochures-books/page__view__findpost__p__4908287
This is the stagea options catalogue, there would be some crossover between the two, but who can find a V35 option brochure?
Oh, and I have a new personal Fav. - Powered Jack KKC935
Tyre changing like a boss....
Oh FFS.
k - go.
U just mad cauz u dont have a flare like me :nyaanyaa:
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
