Get underneath and twist the tie rods/rack ends; I bet there's a clunk. I just had an alignment on mine, and this has disturbed the inner rack ends; which have developed a knock.
They appear to be the same as V35 and 350z rack ends from my search of common part numbers. Can anyone confirm?
V35/350Z ball joints are the same. I've just had mine fitted and the car feels amazing.
eBay is the place to get them. Nissan will only sell the entire setup, at $800/side.
I also checked Ebay but with no luck finding them today
You need to get a computer. It'll make things much easier compared to trying to use your phone. Not trying to be an asshole, just trying to help!
Pretty sure this is where I got mine from, but with the exchange rate they're cheaper now: http://www.ebay.com.au/itm/2-FRONT-LOWER-BALL-JOINT-NISSAN-350Z-03-09-/250697175942?pt=Motors_Car_Truck_Parts_Accessories&hash=item3a5eb75386#ht_863wt_891
Pretty sure this is where I got mine from, but with the exchange rate they're cheaper now: http://www.ebay.com....86#ht_863wt_891
How long did they take to arrive? I'm looking at getting my rack ends through him.
is there a front and rear set of these?
cos I can occasionally hear clunking from the rear...
Let me know if you locate the clunking at the rear. Mine started making a clunking noise a month or so ago & unable to work out what it is. Seems totally random, not just turning a particular direction, accelerating, decelerating, bumpy or smooth road - can't get a handle on it. Audible from outside too.
Edited by Commsman
Less than a week. Pretty happy all round with them - very quick (coming from Taiwan) and very cheap).
Isn't the rear clunking normally the sway bar links/mounts?
Sway Bar mounts & links are normally fairly repeatable; they either do, or they don't. They also load & unload fairly regularly, so they tend to be fairly vocal.
There is a ball joint in the upper "A" arm in the rear, the rest is bushes. Shouldn't be too hard to apply some leverage to the arm to check for noise.
Mine is exactly the same...random...
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
    • I have information on this for anyone that comes looking again. https://www.facebook.com/share/p/18gsbFaYTU/ The rb25det neo from the stagea has the same sumo as rb26 and r32 gts4 (and other awd models). The sump that has caused so many problems during swaps are from the awd neo Gloria's. The casting numbers on the block and oil pans are different so this may help identify if you can't confirm where the motor came from
    • Not feasible to fix the boot lid you had? Damage looked minor/hard to even see :p Source: Drove into something recently and you should be happy you didn't!
    • Another new used boot arrived at the painters, it was sent back as there was nearly as much damage as the original one I want to replace  Finding a clean used boot lid is proving problematic, and I'm not keen on dropping $1500 on a new one from Mazda Sigh....
