  • Replies 96
1331804700[/url]' post='6275889']
Nothing at all wrong with the Stag mate.
Totally agree with that. A tastefully modified M35 like the blue one Ben sold earlier this year is on my shopping list - again when the boss allows it hahaha
go make a beamer appreciation thread! :P:yucky:
I had to take a 2nd look at the thread title myself and thought, "someone's going to rant about bimmers sooner or later & he's probably going to be an aggro person" - & I was right...
and because the thread is about ppl having pies at Robertson - that aggro person will be wrong! :nyaanyaa:
BTW have you dared tell anyone yet that you had an enjoyable ride in a 530i two days ago? :P
Bimmers are crap, buy an Audi :P
Everyone knows Audi drivers are the new BMW drivers. Their typical habitat is 5cm away from your rear bumper, with their christmas light look at me LEDs on. Bimmers are back to being enthusiast cars.
thats what top gear said, although they called said drivers 'cocks' hahahah
Exactly mate. :)
I remember the 'cockometer' they had on Top Gear but the E92 M3 'won' that one over the Audi and Merc!
I don't mind Audis actually, mostly the early 2000s ones like the RS4 (both biturbo V6 and 4.2 V8) and S8, but also the newer R8. Most of the current ones don't do much for me.
They can get within 5cm of your rear bar?
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
