could not find anything on this topic for days so here is my problem
it will rev to 2000rpm and back to 1500rpm
rb30det w/ S1 rb25de head and std internals
rebuilt std vl turbocharger
rb25det exhaust manifold
S1 rb25det ecu. tried s1 rb25de ecu and s2 rb25det ecu
nizpro hidden intercooler
has anyone had a similar problem?
here is a video
http://www.youtube.com/watch?v=I0G05z-7mIU
Edited by crispyvl
https://www.sau.com.au/forums/topic/394398-rb2530-wont-idle-properly/
did you use a turbo block and pistons or NA block and pistons?
You haven't given much info.
But a factory ECU isn't going to run a different capacity engine, and different turbo very well.
Stock ECU or maps has idled fine on all my 30's, I would be looking for a vacuum leak or checking the afm connections.
OK. I wouldn't have worried about non-turbo injectors, as going smaller is hardly going to help. If you've tried a different IAC valve, let's just be sure we're talking about the correct valve. There's two involved in the idling of the car. The IACV is the one at the back end of the plenum that is motor controlled by the ECU to control the idle speed at all times. The other valve is hidden under the plenum and is the cold start valve. It's electrically heated and is open when cold. As it warms up it closes off the extra air that it lets in for a cold fast idle. You don't want to play with that one, it's the IAC that's important. If you've changed the IAC with no change, are you sure that the wiring and connector for it is sound?
Also, do go look at the codes. You might find the answer right there.
I had the same issue when i cleaned my throttle bodies in my first GTR.
Also in my old r31 but that was due to dud iac valve (idle motor)
Try crimping the hose that feeds the idle motor to see if the idle drops.
Make sure the throttle cable isnt over adjusted. Make sure throttle plate is fully closed.
Make sure idle adjustment screw is wound all the way in.
Make sure cooling system is bled
will it matter with no coolant because it doesn't have any in it what so ever
Sounds like a wiring issue to me.
I'm pointing straight to the AFM for the time being. I have seen similar things with dud AFMs / No AFM connected / Incorrectly wired AFM.
Because VL's wiring is SOOOO gay, and most people dont know how to correctly wire up RB's, most people miss the fact that some of the sensors have a separate power feed fed by a brown wire, and most people dont even both wiring up the crank signal, most of them run like shit.
I'd check the AFM, if you are not electrically minded, get a mate that knows RB's wiring WELL. Check for the obvious too, IE, vacuum leaks.
It is possible that the IACV doesn't even have power to it, one pin should have +12V when the ignition is on. The 0V for this valve is controlled by the ECU.
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
