So please outline exactly what is different now that it is a DE+t...
The fact that you a swapping and changing parts between s1 and s2 when they are known to be different is quite perplexing..
rb25det s1 injectors
rb25det s1 ecu
What airflow meter?
Also get yourself a consult cable and a copy of Datascan or ECUTalk, check for error codes and see what is happening when the idle is hunting.. is it trying to chase the idle with the IACV? or is it doing it via timing?
Have you checked your base and cam timing?
P.S. building hybrid engines of this sort you really need to have a good idea of what the ECU and all sensors are seeing/doing otherwise you will just be chasing your tail when issues like this arise (such as you are now).
Hey Bro have you tried cleaning your aac valve system, i did this to my rb25 on the weekend and car idles were it should, use to idle round the 2k mark,
im not sure if you have a "pulsing idle" as goes from 1500 to 2000 and back and forth, also check that your Throttle Positioning System electrical plugs are pluged in properly and not dirty?
just some hints that you could possibly try?
links below if you want to read more about AAC
http://www.skylinesaustralia.com/forums/topic/110431-diy-aac-valve-cleaning-idle-reset/
Cheers
It's not AAC. It's IAC. ferchrissake.
Nissan Actually calls it an AAC dude.
Auxiliary Air Control valve. IACV is the same thing just worded differently. Idle Air Control Valve.
But Nissan call it an AAC valve.
Then there is the cold start valve which isn't controlled by the ECU, along with the FICD or Fast Idle Control Device.
there is actually 2 idle devices
aac - aux air control
and
iacv - idle air control valve
in r34's they integrated them but the aac i believe is the one under the manifold that brings the revs up when you cold start, iacv is the one bolted to the back of the intake manifold
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
