1: enkei rp01 17 x 9 +22
just had them resprayed silver (matched to the original colour).
$900 + $50 postage Australia wide.
enkei rims
2: Garret turbos for a GTR. 2860 -7
Just rebuilt by Precision Turbos. Both have brand new bearings and the exhaust housings have been ceramic coated in black. As good as new and haven't been used since the rebuild.
Part numbers from the cores:
HH 0110J
14411-AA403
707160-7
Part number from actuators:
430819-369
08223
35367
$1600 + $50 postage (includes insurance)
turbos
3: R32 GTR Fibreglass front diffuser
See the link for details as it is the one I bought.
R32 GTR diffuser
$220 + $25 postage
4: Speedline 17 x 9 +25
Tyres are dead but may pass rego. I lost one centre cap on the road sad.gif Comes with the centre cap tool too. smile.gif
usual small gutter rash
$400 + $50 postage
speedline SOLD
5: 4" stainless exhaust
Front pipes to back
only used for a short time by previous owner, catco cats on each leg of the front pipe. Will need to be welded back together. I cut it up to squeeze it in my car.
$400 can be posted but unsure of postage costs.
exhaust SOLD
6: r32 GTR side skirts 2 pairs
both need straightening and one set needs painting, the other needs a GOOD polish
just take them. SOLD
7: RB26 block with rods pistons and crank (pistons and rods removed from block)
no cracks, all is in good nick.
$200 SOLD
7: RB26 standard rods and pistons in excellent condition.
$100
9: used aftermarket rb26 manifolds not sure on brand, no cracks, provisions for heat shields
ceramic coated black
$200 + $20 postage
manifolds
11: R33 GTR aircon compressor sold as is
$50
air con compressor
12: R33 GTR standard clutch, flywheel and pressure plate USED
$50
clutch NO LONGER FOR SALE
13: N1 water pump used
$50 + $12 postage
14: N1 oil pump used, not cracked
$50 + $12 postage SOLD
15: ex BSM R32 GTR sump, with baffles and extended pan
needs a donor sump for the diff parts
$850 + postage
sump
16: standard r32 gtr sump good condition
$200
17: ex BSM R32 GTR Quaife front diff centre used but in good condition
$1200
quaife SOLD
18: tomei pon cam replicas bought from dirtgarage (who used them for a short time) then not used by me.
260in 260ex 9.15mm lift
$400 + $20 postage SOLD
19: R32 GTR fibreglass N1 bonnet lip painted in white NEW
$80
lip
20: R32 GTR fibreglass N1 boot lip painted in white NEW
$160
lip SOLD
21: R32 GTR Trust style fibreglass rear pods painted in white NEW
$160
pods
22: Simota Air filters to suit R32 33 34 GTR
$50 + $15 postage
http://imageshack.us.../img0117ya.jpg/
23: Apexi AVC-R Boost Controller USED but everything is there.
$350 +$15 postage
http://imageshack.us.../img0088mu.jpg/
24: UAS Pivoting Front Upper Arms
$500 +$20 postage
http://imageshack.us.../img0090qw.jpg/
25: GK Tech Rear Upper Arms and Traction Arms
Comes with the updated parts.
http://www.gktech.co...32%20Skyline#13
$199 for the Upper Arms and $129 for the traction Arms. +$20 postage
26: 2 Genuine Z32 AFMS (brand new and unused) with used plugs
$500 + $15 postage to anywhere in Aus.
http://imageshack.us.../img0060xg.jpg/
27: R32 GTR Bilsteins
Unsure of the spring rates. No leaks and in good condition.
$350 +$30 postage
http://imageshack.us.../img0091ps.jpg/
28: R32 GTR Ohlins
Unsure of spring rates and they are leaking. One has been pulled apart but everything is there as I was going to tinker with them.
Free to a good home. $30 if you want them posted.
http://imageshack.us.../img0093vz.jpg/
29: R33 GTR alternator
Unsure of condition. Came off a running motor.
$50
http://imageshack.us.../img0095co.jpg/
30: S13 Quick Shifter
Unknown brand. doesn't include the actual stick but it should be hard to get something put on.
$50 +$15 postage
http://imageshack.us.../img0096wq.jpg/
31: R32 GTR engine covers
Could do with a respray.
$100 +$30 postage
http://imageshack.us.../img0097tu.jpg/
32: RB26 Eagle Rods BRAND NEW
$580 +$20 postage
http://imageshack.us.../img0101pc.jpg/
33: R32 GTR HICAS steel lines that run from the front to the rear of the car.
Might be handy as fuel lines as they bolt straight into a standard car.
http://imageshack.us.../img0102kp.jpg/
34: R32 GTR oil pumps
Both used but in need of a good clean. See the picsfor the condition of the pumps where they are driven.
$40 each + $15 postage
http://imageshack.us.../img0105pn.jpg/
35: Apexi Pen type turbo timer
$10 +$7 postage
http://imageshack.us.../img0108gs.jpg/
36: Ruzic Enginerring 4WD controller. Brand New and unused.
$450 + $15 postage
http://imageshack.us.../img0055ln.jpg/
37: Single din socket for skyline dashs
Put things on there.
$10 +$7 postage
http://imageshack.us.../img0110ox.jpg/
38: R32 GTR ignitor used
$50 +$10 postage
http://imageshack.us.../img0111ih.jpg/
39: R32 GTR CAS used
$50 +$10 postage
40: Fidanza Vernier Cam gears
Brand new, never used
$170 +$15 postage
http://imageshack.us.../img0112jr.jpg/
41: R33 GTR standard gearbox sandwhich plate
Used
$20 +$15 postage
http://imageshack.us.../img0113kx.jpg/
42: Ross Tuffbond RB26 Alternator pulley
Slows the alternator down, good for engines that spend alot of time at hi revs. Unsure of speed reduction but pulley dia is at the peak of the grooves where the belt runs.
$50 +$10 postage (small pulley for the alternator)
http://imageshack.us.../img0114ib.jpg/
43: Ross Tuffbond RB26 Waterpump pulley
Slows the waterpump down, good for engines that spend alot of time at hi revs. Unsure of speed reduction but the pulley dia is at the peak of the grooves where the belts run.
$50 +$10 postage (large pulley is for the waterpump)
44: Rice Racing water injection
http://www.riceracin...r-injection.htm
Requires fab work to install and setup properly. Due the way this setup works it is better than the setups that use an electric pump to create pressure as it creates a finer mist which is the key to water injection that works especially pre turbo. the only downside is it requires a bit more thought when it comes to the installation.
PM me if you have more questions.
$850 +$20 postage insured
http://imageshack.us.../img0084pj.jpg/
45: Used Nismo FPR
$20 +$10 postage
http://imageshack.us.../img0085ib.jpg/
46: Autometer Pro Comp UltraLite Water Temp (in degrees F) and oil Pressure (in PSI)
Used. Comes with mounting brackets. Both gauges are mechanical.
$50 for both +$10 postage
http://imageshack.us.../img0087lx.jpg/
49: Nistune ECU + PLMS USB consult cable for a R32 GTR
Never installed the chip into the ecu. Comes with all the instructions and a R32 GTR ecu (minus the case). Will provide software keys and help with the transfer of the registration to the buyer.
$300 +$15 postage insured
PICS TO COME
50: XS Engineering throttle body shaft seals for RB26 throttle bodies
Fix those leaking throttle bodies with these :)
$100 +$10 postage
http://imageshack.us.../img0075cy.jpg/
51: 2x EGT K Type thermocouple plus plugs and a 2 channel amp
These exhaust gas temp sensors will fit the Tomei manifolds I am selling. The K Type thermo couples are a high quailty temp sensor that will easily handle the hi exhaust temps found post turbo. The plugs are specifically made to work with the temp sensors and the 2 channel amp turns the signals from the sensors into something an ecu (even Nistune) can read.
http://imageshack.us.../img0076fp.jpg/
52: Jaycar Courtesy Light Delay kit
Assembled and used (so it works properly) but my alarm didn't like it.
$10 +$6 postage
http://imageshack.us.../img0083cc.jpg/
53: M12 x 1.5 wheel nut set contains 20 nuts and a tool to do them up.
I was sent the wrong nuts.
$20 +$10 postage
http://imageshack.us.../img0081ht.jpg/
54: NTK 02 sensors to suit a R32 GTR (Titania type) x2
Ready to bolt straight in with the correct plugs attached.
$220 +$15 postage insured
http://imageshack.us/photo/my-images/145/img0074v.jpg/
I also have bits and pieces from a complete engine. No block or head. have exhaust manifolds complete inlet plenum and heaps nuts and bolts, coil packs, wiring, knock sensors etc. PM me if you need something.
Will post at buyers expense. Pick up is available from Quakers Hill
Josh
Edited by dontfeelcold
49: Nistune ECU + PLMS USB consult cable for a R32 GTR + Individual Tuner License + R32 GTR ECU (minus the case)
$560 +$15 postage insured
http://imageshack.us/photo/my-images/43/img01281w.jpg/
