S: Assorted Brand New And Used Performance Parts - Cheap!
Hi All
I have a number of parts for sale. See bellow for prices and pics (or try http://118.127.2.168/carsale/):
Bosch 044 - brand new in box - $180
Blits Bonnet, brand new, never used, only thing done to it is to fit windscreen washers - $700 - ADR Approved aftermarket bonnet
Random Highflow cat, unknown brand, $120
RB26 front pipes, twin 3" inlet to 4" outlet, $220 - this things a monster and will flow bulk hp - will throw in a muffler that used to bolt to this for the flange, if buyer wants (shipping etc)
SuperSpark coilpacks to suit early RB25 and RB26 - Never used, in box, $350
R32 ReinHard Dual Tip Exhaust - Sits super tight in the tunnel, good for keeping ground clearance, 3", will flow heaps of HP - $500
SuperCat 3" Muffler /w flange and mounting brackets to suit the R32 ReinHard exhaust above, for swapping it on and off (noise etc) - $250 or $600 for both - flows well enough, good for shutting something right up.
HKS R33 Catback, 3.5", good for much HP again, some scratches to the bottom of it, $500
Gktech Dump and front pipe into CatCo high-flow cat, made to fit a RB25-equip R32, should fit R33 or RB20 R32 but unsure, 3 bolt flange, also comes with small tip off cat for track days, $150. Wrapped in heat-wrap.
R32 GTR JJR Adjustable Upper control arms, brand new never used in packet, up to 5 degrees negative camber, $300
Will post anywhere at buyers expense. Located in northside brisbane, pickup definitely an option.
My number is 0400 813 419
Edited by IanB
    • They work on really anything track related now. They do my mates r35 gtr and it's a weapon of a car.
    • I use the penrite 600f in my cars and have had no issues even at Townsville v8s when I drove that but I bled fluid end of day for just in case. Good value and a about 38-40 on sale. Use castrol srf on the supercars and no need to Bleed brakes over a race weekend. Do the 1000km with no issues. Over 120 a bottle I seen at repco. A quality brake pad is always a good starting point the ebc stuff I've seen let go after 2 sessions with heavier cars. I'd be going to a decent track pad and maybe those porsche air guides on the control arm to help with some air over the rotor. Helps on 86/brz with stock callipers.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
