Hi all,
I have a problem and wondered if you can give me your thoughts please.
I have a 1998 R34gtt with about 70,000 miles and running a GT3076r and a Link G4 plug and play ECU running a 5 bar map sensor. It's been mapped on a dyno dynamics rig to 498hp at the flywheel. Internally it's stock apart from a 1.6mm metal head gasket. (Fmic, oil cooler etc) I have done 9000 miles with the car in this spec.
The problem:
Yesterday the water temperature started to climb, which also caused the oil temps to rise. General overheating occurred which resulted I'm a peak temp of 101 deg oil temp and 120 deg water temp before I shut it down. It will cruise on the motorway off boost for quite a while (70+ miles) and stay under 100deg water temp and about 85 deg oil. However, when you hit roundabouts or built up areas and speeds below 40mph she starts to overheat, heat soaks everything and it's all over. The top hose feels hard.
I pulled the thermostat and that's working properly. I pulled the water pump and that's perfect too. I have re-bled the cooling system and that's got no air in it either.
I think that the head has lifted and probably caused gasket failure between the water passage and cylinder or I have somehow cracked the head. But can anybody else give me any better ideas?
Cheers
Chris
https://www.sau.com.au/forums/topic/394441-rb25det-neo-water-temp-problem/
Is the radiator fan operating correctly? Assuming the OEM fan and shrouds are all in place.
Do you have evidence of coolant in the engine oil, or oil in the coolant?
probably the radiator
mine (50mm jjr one) got clogged (flushed the system with the cleaner stuff before i put the new rad on, but it just loosened it all up and eventually washed it into the new rad)
see if you can get it cleaned out
i ended up getting a new stock size rad off ebay (koyorad) for about AU$220 (the top tank split on my old stocker, hence the new alloy one)
  • 3 weeks later...
Okay now I'm totally boggled.
I have done a block test and it's come up clean, I have done a compression test and it's come up at 140psi (give or take) right across the board.
Oil is good, water is clear...
Took it out for a drive and boosted it to 1.4 bar. No problems until it got hot. When its at good temperatures it boosts fine, when it gets hot!- its almost like it hits a boost cut or is blowing out the spark when it hits high boost and WOT.
Engine doesn't overheat when standing idle ticking over - warms up correctly. Doesn't increase in temperature when already hot/overheating when then left to idle.
Plugs looked a good colour, not black or sooty, not white or charred. A nice light brown colour.
Drives perfectly fine off boost. ECU doesn't throw any other fault codes.
Engine doesn't smoke or pop balls of smoke in any way.
Does anybody have ANY idea? I'm utterly stumped.
Could the turbo be on its way out and cooking the water? It's only 10k miles old and doesn't make any noise or smoke?
Somebody mentioned that when the bearings are really warn they cause excess heat? But wouldn't this happen when just driving normally off boost too?
I really just have no damn idea.
Do a leak down test sounds like hg I recently bought a 26 with a busted head gasket was running fine just getting hot pulled the head off and the gasket was gone. Replaced it did a leakdown and cam back perfect results
In terms of cost and ease, you'd be better of trying to put a stock radiator in and retest (put the shroud back on too with the stocker radiator).
much quicker, cheaper and easier than pulling the head off.
Radiator cap in good condition?
New ones from Nissan are pretty cheap.
Edited by GTST
This is because the Link will have a temperature MAP lockout. Once it goes over 100'C it should throw a CEL to tell you. And anything over 100'C the MAP limit will more than likely be alot lower.
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
