Haing a clean up of what parts i still have after parting out my 32 gtr. also have some 33/34 and silvia parts too.
call or sms me (brad) on 0437 198 210
can get pics if needed.
pick up preferred from upwey or dandenong.
fairly frim on prices as they are cheap as it is. priced to sell asap. :cheers:
R32 GTR
Injector Resistor Pack $50
Oem Gtr Side Skirts (2 piece) $100 pair
Brake Booster $60
Brake Master Cylinder (abs) $80
Brake Booster Tank (bolts next to brake booster behind the strut tower) $30
Abs Unit $100
Power Steering Res $40
Power Steering Rack $100
Power Steering Pump $60
Lower Control Arms (both sides) $50each
L/H Front Driveshaft $100
Castor Rods (both sides with nolethane bush's) $80 pair
Front Sway Bar $30
Front Sub Frame $50
Front Hubs/Knuckels $50 each
Speedo Cable (same as gtst) $40
Acc Cable $30
Windscreen Wiper Motor $30
Windscreen Wiper Arms $10 each
Aircon Compressor and lines between firewall and condensor $80
Complete BOV + Return Setup (everthing from drivers side to the pass side inner guard $160
Clutch Master Cyclinder $30
Clutch Pedal $20
Brake Pedal $15
Acc Pedal $15
Centre Dash Vents $50
L/H Dash Vent $30
Stereo/middle Surround with Astray (shiny finish) $40
Cluster 41,510 km's $120
Cluster surround with Clock $40
Roof Lining (could do with a clean) $10
Factory Boost Gauage Map Sensor $15
Drivers Side Reversre Light $30
Pass Side Reverse Light (one of the mounts is snapped off ) $15
Cooler Piping
Drivers Side guard to manifold $15
Drivers Side Guard to Cooler (have 2 of these) $15
Pass Side cooler to Guard $15
Rear Brake Calipers $120 pair
Pass Side Kick Panel (covers ecu) $10
R33 and R34
R33 Rb25Det Throttle Body x 2 $40 each
R33 Rb25 Coilpack Cover $30
R34 Rb25 Coilpack Cover $30
R33/R34 GTR Airbox Guard Duct $30
R33 Rb25det Aftermarket Top Feed Fuel Rail (brand new never used, comes with adapters for conversion to top feed) $100
R34 Gtt Rb25det Exhaust Std Front Pipe $30
R33 Gtst Rear Brake Calipers $80 pair
R33 Gtst Intake Pipe(with bov return and rocker cover breather pipe) $20
R33 Rb25det Fuel Rail With Injectors $70
Silvia and others
S13 Sr20det Std Boost Solenoid $10
S13 Centre Console and Ashtray $15
S13 Ca18de Intake Pipe $20
S13 Sr20de Intake Pipe x2 $20
S13 Ca18det Airbox $100
S13 Sr20 Inatke Manifold (no injectors/idle motor) $40
S13/S14 SR20 Ignitor $50
S13/S14 SR20 Power Steering Pump $50
S13/S14 Sr20Det Std Injectors x4 $50
S13/S14 6 Bolt Drivshafts (pair) $50
S14 Speedo Cluster Surround Trim $20
S14 Sr20DET Radiator/Shrould/Thermo Fan (has a few dents and bent fins) $40
S15 6 Speed Manual Tailshaft $40
Soarer 1jz Std Exhaust Manifolds (pair) $40
350z Std Cats (low km) $80 pair
https://www.sau.com.au/forums/topic/394459-r32-gtr-part-out-left-overs-melb/
  • 1 month later...
  • 9 months later...
*EDITED*
only have whats listed below, sold items deleted.
R32 GTR
Abs Unit $100
Front Sway Bar $30
Front Sub Frame $50
Acc Cable $30
L/H Dash Vent $30
Cooler Piping
R33 and R34
Silvia and others
