gday guys up for sale is my garrett gt2835r and was running on my rb20 for about 6 months.
was originally off a rb25 and i puchased it off another forum member.
probably better suited to a rb25 rb30 as it was quite laggy on mine.
im no expert on turbo's so im unsure of sizes of wheels etc. but if you let me know where u need measurments from i am more than happy to do so.
included in the sale is a couple of braided lines, 4" to 3" silicone reducer, about 150mm worth or 3" silicon hose and a few gaskets.
oh and also a 3" front/dump pipe is included and a 12psi actuator
the reason for sale is the internal wastegate was jamming and also i wanted somethnig more responsive.
the wastegate may be an easy fix im not too sure.
shaft play is minimal
asking price is $550 which i think is reasonable but may be slightly neg depending on what mood im in :P
located bayswater Vic
Edited by TJR32GTS-T
https://www.sau.com.au/forums/topic/394485-garrett-gt2835r-vic/
    • Could someone post some pictures of the factory Jack , tools, spare tire and how they were in a 1998 ER34 2 door skyline originally?
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their proven reliability, predictable performance, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
    • I've previously seen people post up "dress up bolt kits" for RBs but don't remember seeing them specify the full contents. I can only really suggest you grab the verniers and start measuring, and keep in mind the cam cover and timing cover bolts are both quite specific with a wider unthreaded section where the bushes sit, that will make it hard to get aftermarket replacements which tend to be all thread (set screws) or for longer bolts a flat section with a shorter threaded section at the end
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
