Owner/ Builder of highly modified R31 Nissan Skyline! Fully engineered, Mod plated and road legal with Tasmanian registration. Suit buyer looking to join a car club for track use or someone wanting a unique weekend car.
On the current tune using Bp 98 ultimate fuel power output is 370rwkw (500hp) at 23psi and 290rwkw at 15psi.
all modifications have had meticulous attention to detail and will not disappoint! Genuine enquiries only! Happy to talk to a potential buyer about the full list of details about the car.
$27000 negotiable
https://www.sau.com.au/forums/topic/394512-highly-modified-r31-nissan-skyline/
Engine - Rb30et, standard crankshaft grub screwed, polished and wider oil pump drive fitted, 1mm oversized hypertec cast pistons, spool h beam conrods, arp rod bolts, mains and headstuds, new genuine nissan rb20det oil pump, 1.5mm tomei oil restrictors in block, ACL race series bearings, gaskets and 3 layer steel headgasket, ASR competition sump, reconditioned rb30 head with oversized stainless valves, performance branded springs and retainers, custom ground cam by tighe cams, 3.5inch exhaust with hi-flow stainless rear muffler
Driveline - Rebuilt OS giken Twin plate clutch and R33 gts-t 5spd gearbox, single piece 3inch tailshaft, rebuilt LSD with 3.89 final drive
Suspension - HSD Coilovers, Whiteline adjustable sway bars, full nolathane bush kit , adjustable caster rods, whiteline strut brace, rebuilt s13 front hubs and s13 lower control arms with new ball joints.
Brakes - Ksport 8 piston front calipers, 330x32mm slotted/vented rotors with ferodo ds2500 pads, rebuilt r31 rear calipers, rda slotted rotors and a1rm pads, stainless braided lines all round runing motul rbf600 brake fluid, standard handbrake with new cables, new PBR 1 inch master cylinder with brace, brake ducts fitted to front for additional cooling
Stunning car and mods! Although I'm looking for an R31 GTS-X, this still sparks an interest. I'm sure it's had $27K spent on it but I think you'll find it hard to sell it for that much. Good Luck though!
that thing is jizz worthy. Worth every cent when you think of it in dollars spent.
Hopefully the right person comes along with a heavy wallet.
You'll be lucky to get $12k for it regardless of how much has been spent on it, the reality is no one who has $20k wants an R31.
Part it out and you'll make way more.
This.
  • 3 weeks later...
Hey 'Rolls' why dont you go fag up your boyfriend rather then my thread???? Cheers!
Yes i live in Tasmania 'Maxima' and yes the house in the background was built in 1956 to be exact! off topic a bit ? Haha
Well 'Smkr31' the Turbo set up is,
Borgwarner/airwerks s300sx 83/75 (like a gt35 with a t04z turbine) 6 boost twin entry manifold ceramic coated aswell as the turbine housing, turbosmart 50mm external gate with exit pipe, 3.5inch exhaust with single stainless rear muffler with 4inch outlet.
ID 1000 injectors, 2 x bosch 044's, 4.5L surge, twin -6 supply lines and -8 return with speedflow fitings, SX fuel pressure regulator.
Haltech E11v2 will full loom wiring in including 6 x LS1 coils and a Eboost street control the setup.
Thanks.......
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
