I have a fully built Dodson GR6 transmission
Parts list below, pretty much the full Dodson Catalog.
our race only car is going to a lightweight specially adapted rear wheel drive transmission which is a change in direction after our new transmission was just finished being built in December. The transmission has never been used (other than the standard Run in and check by the Dodson authorised Technician test car). Also has all the new Dodson tranny and diff oils. ATS Carbon Rear diff.
All the parts are brand new. Read: Brand new promax clutch, Brand new 1-6 straight cut greatest. and all the parts listed below.
We also have a a billet transmission selector fork installed (this is the fork that failed in my transmission originally)
I don't need a transmission swap but will consider if it makes the sale.
The full build cost and supply of a second hand transmission would fetch AU$55,000
Will sell for $49,000.
Steve Thatcher From JustJap in Sydney (the Dodson authorised australian technicians) will happily answer any questions/verify the work and the install. his email is:
Steve Thatcher [email protected]
R35 CPM PRO MAX COMPLETE CLUTCH 1000 FT/LBS+
R35 MC1 2MM MECHANICAL CIRCLIP 1 2MM
R35 MC2 MECHANICAL CIRCLIP 2
R35 GL GEAR LOCK FOR FWD TRANFER GEAR
R35 ORK O RING KIT
R35 OPK OIL PUMP UPGRADE AND REPAIR KIT
R35 DCS HIGH TEMP DIFF SIDE COVER SEAL
R35 TP BILLET ALLOY TRANSMISSION PAN/SUMP includes R35MK
R35 TF TRANSMISSION FILTER REUSEABLE
R35 TFP TRANSMISSION FLUID + 30 DEG AMBIENT
R35 DO1 HEAVY DUTY DIFFERENTIAL OIL
R35 ETS ENGINE TEMP SWITCH 68 DEG C
R35 RSS HEAVY DUTY CLUTCH RETURN SPRING SEAL
R35 OPP OIL PUMP END PLATE AND GASKET
R35 6SGS SC 6 SPEED GEAR SET STRAIGHT CUT
R35 FWDCH FWD UPGRADED CLUTCH HOUSING
R35 FWDCP FWD UPGRADED CLUTCH
R35 FWDP FRONT WHEEL DRIVE PINION
R35 FOS FWD OUTPUT SHAFT
  • 5 months later...
    • I'm late to the party on this one but good to see common sense has prevailed and the turbo kit is coming.
    • She's looking good Greg. Colour suits it perfectly 👍
    • I had a look at the FAB9 EFR kit, around $8500 AU before delivery, so add in shipping, installation, consumables and tuning, I believe the price difference would be negligible  And whilst I am paying top dollar at MX5 Mania, if I have any issues with the kit they are local for support,  and from my experience, will happily go out of their way to help, hell, I've purchased parts from them and asked "how do I install or remove parts" and they have fitted a few of them for free, this means more to me than saving a few thousand dollars And yes, 99% of the time I just plod around in the car, that may change once I start hearing turbo whooshy noises, but, as I have 3 family members is the constabulary, even when I'm up it, it is only up to the speed limit, or occasionally, but rarely, overtaking on the Hwy (I just plod in the left lane typically and enjoy the drive) Plus the kids would never let it go if I got booked speeding, Jackie is constantly getting critiqued by the kids about her driving, which I think is hilarious, and tell them that she is "bringing shame to our family", so heaven forbid if I ever got done speeding, after all my mouthing off about her driving, I would never live it down, and it would be another thing she would bring up any chance she got Like the time I got drunk about 15 years ago and fell out of a cab, which gets brought up at least a few times every year since it happened Good times
    • True, might get it looked at. Found out you can in fact flatten the 12v battery relatively easily too the other day (kids lefts the hazards on) so meaning to get that checked in the new year. What's odd is it'll blow cold from both vents if you have the ac down as low as poss (18), but anything else the passenger one blows warmish. Also has been summer since I got it obvs but noticed it didn't seem to want to blow hot last night when we had a cold snap.
