Hi All,
In July 2010 i built an RB30/26 with the quench pads removed from the head mated to Endyn softhead pistons (for a friend) It seems to have ran well so far and the folks mapping it say she's strong etc. As it turns out i have done the head gasket on my 25 neo I’m going to pull the engine and do a rebuild on the bench while it's out. I think i have managed to find a 26 crank, rods and 87mm wiseco pistons for a good price which I’ll throw in for good measure.
By banging a neo head on top of that little lot, the CR backs out at about just under 10.3:1. I was planning on pulling the quench pads out of the head which should let me drop about 9cc's from the combustion chamber and with a 1.2mm gasket leave me with 9.2:1 compression ratio.
I think most are pretty argued out on the whole "remove/don't remove" the quench pads debate. But does anybody have any experience with removing the quench pads on a neo head? If so, how many cc's are gained in the combustion chamber by doing it?
Cheers
Chris
https://www.sau.com.au/forums/topic/394541-rb25-neo-quench-pad-removal/
Just been through this exact saga myself.
26 Crank, rods and pistons. CP pistons at 86.5 bore have 15.5~cc dome. My NEO head was 54cc, And I had originally bought a 1.2mm gasket. (nearly 11:1CR from memory)
Long story short I had the head taken out to 57cc and added a 1.8mm gasket which landed me at 9.3:1CR.
Ahh!
You know what, skyline Australia forum is genuinely the best skyline form in the world. The UK forums are okay, but for technical knowledge this place is the poodles privates.
What did you take out of the head to get your 57cc?
Thanks Again
Chris
You could look at just deshrouding the valves by scalloping into the quench pads each side rather then removing them completely. Then see what that gets you in chamber volume and use headgasket thickness to achieve the rest.
WIth fuels and tuning as good as they are these days, you can run in the mid to high 9's without any worry. It's only going to help off-boost drivability and reduce lag.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
