That hose on the TB goes to the charcoal canister aswell mate. I tried blocking that and the BOV hose off aswell as putting zero pre-load on the wastegate arm. STILL hitting 20psi in 3rd gear! Also noticed the whole actuator and bracket its bolted to shifts forwards a little bit when i give it some compressed air.
Thankfully Stao is sending me a 7psi actuator, i'll see how that goes.
It shouldn't move, flex a little perhaps but only at the end of its stroke. So if the wastegate flap isn't sticky then the bracket must be loose? Perhaps the bolts into the housing were a little too long and they bottomed out in the thread?
A 1 bar actuator should start opening at around 20psi using the compressor with no manifold pressure. Just thinking, if there is less restriction in the rear housing then the pressure would be lower, with less force pushing the puck open. Wouldn't that raise the boost threshold of the actuator a little anyway?
Yeah i probably didnt word it properly, its more like what you described. I checked that the bracket is on there and not budging.
  • 1 year later...
Well. There has been many G3 and SS series been built through the year, the spec of the turbocharger varies, the internal gate assembly is matched to suit the application its designed for. Which not necessarily made for 14psi that can be rised using a EBC to reach 24psi.
Relating to the latest incident, it turned out the dump pipe bolts used are too long that fouled against the internal wastegate flapper. So its no longer spiking at uncontrollable boost level.
Regardless, if a turbocharger is made for a internally gated 280~300rwkws application then it is obvious that it will be running in between 18~20psi of boost.
If this turbocharger comes with a 20psi assembly then lowering boost level by change in actuator will not result in significant differences in the minimum boost level archived.
I can not use a 14psi internal gate assembly to hold 20psi nor using a 20psi internal gate assembly to run 14psi. In which the assembly it self has been setup for this purpose.
To clear the intention of purpose I do ask a lot of questions before proceeding in building any turbochargers.
Below is a demonstration of two different internal wastegate assemblies:
Purple is made for 14psi, made to run 20psi.
Blue is made for 20psi, did every thing possible to run at minimum boost level.
Orange is made for 20psi, run at 20psi.
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
    • WRXs are a pure pleb boring car these days. You need to get an STI to even get close to what a WRX used to be.
