Right, I've hopefully sorted out all my issues :D
First of all, the catch can is on it's way back to Brad to be modified to suit the new intercooler piping. Hopefully I worked out where it needs to be modified correctly, but I gave it a bit more room than I thought it needed for safety. Fingers crossed it doesn't affect the catch cans functionality too much, but I don't think it will. Revised catch can will have some Earls fittings as well, so I'm looking forward to getting it back :)
Then I phoned up my local brake specialist and managed to source a replacement check valve for the brake booster, will pick that up tomorrow. After some googling, I believe I have also sorted out the throttle cable problem as well. Most people seem to have solved it by purchasing a cable clamp from a bicycle store and clamping off the cable at the accelerator pedal to keep the tension. So I'll drop into my local bike store tomorrow to see what they've got. Fitting for the IAC valve should be sorted out this week sometime as well.
Went and picked up an Earls -12 weld on fitting today, thought it easier than trying to find an appropriately sized pipe cut off. Just at a local fabricator now getting it welded on, let's hope the blokes welding skills are better than his customer interaction skills. What a traumatic experience lol.
But if it's a tight weld and it all works then it's worth it. Bought some -12 hose for the IAC valve as well, but realized too late that this stuff is not very flexible, I'm worried it will kink due to the positioning of the IAC on the Plazmaman. Will find out tomorrow :/
Edited by Hanaldo
Will do a better update with pictures etc. tomorrow, but for now... It's done. All back together, and... I'm ready to burn it. Trailering it to my tuner on Thursday to hopefully get tuned on Friday. If he doesn't finish it on Friday then it will be stuck there until they reopen on the 21st of May, so fingers crossed.
Unfortunately I couldn't sort out the injectors to get it to idle, my NIStune software doesn't work properly and wouldn't sync. So apart from priming the fuel pump a few times and fixing the few fuel leaks here and there that we found, I couldn't do much else in the way of making sure it was all correct. Means I will need to pay my tuner to bleed the cooling system and fix any other mistakes that we have made, of which I'm sure there will be many.
Also rounded the grub screw in the HKS rail as it was leaking so we tried to get it out but couldn't fit an Allen key in between it and the plenum nicely. Was one of those things where you just think it must surely be about to crack loose and then bam, the fkn thing is rounded and it's a drill-it-out job. In hindsight we should have been patient, but it's done now. Extremely pissed off about that. I'm glad it's all finished because I am done with it.
Promised pictures:
Firstly, this:
Is a much better design than this:
And that's one problem solved:
Next up, getting the fitting welded onto the intercooler pipe. What a mission and a half that was. Took 4 hours of driving around before I found someone who would do it, then the first thing the bloke says to me when the secretary (pretty little thing she was) got him for me was "waddya want ya dumb flamin mongrel?". So he had the customer service of a cave troll, but I managed to communicate with him. Lucky for me he knew his way around a tig, and this is what I ended up with:
Very happy with the end result, and that's the next problem solved. Then onto the throttle cable. I came up with an even better idea than the cable clamp, anyone recognize what this is?
It's the throttle cable adjuster off the gyro cable on a BMX. Little modification here and there, and bam:
That's another problem solvered. Had to film the throttle body in action seeing as I didn't have anyone to tell me if it was opening fully or not, so may as well upload that too:
The quick taps was me trying to dislodge the adjuster or see if it would get caught and jam the throttle open somehow, but it's rock solid. Gotta be happy with that. Now we are up to where my previous post comes in, so I'll skip ahead to getting it to the tuner yesterday. Not really a part of the build, but it was interesting to say the least so I'll post some pictures anyway :P Getting a car as low as mine onto a standard car trailer without the use of power brakes or steering is a right challenge. The front bumper had to stay off, the rest we sorted out as we went along...
Took a few tries to get it lined up, was a lot of work between two guys lol.
This is where things started to get tricky:
Very tight:
This was with the trailer parked on a slope to eliminate as much angle on the ramps as we could, AND with the front of the trailer jacked up about 50cm off the ground. Still too tight. Ended up having to get my mates mum and my dad to stand on the back of the trailer to bring it down enough to get on. But finally we did:
Then it took about 30 minutes longer than normal to get to my tuner, so we arrived at about 6pm. Luckily the guys were just hanging around having a few beers and didn't mind us being late, so they came and gave us a hand to get it off. Took 4 of us and two trolley jacks to get it off, but eventually we did and this is where I last saw it:
I was hoping it might get done today, but that was probably a bit optimistic given the extent of modification it went through and hasn't even been started yet. For all I know we did it all wrong and there are a thousand problems with it, so will just have to see. Tuner gave me a call today to say they were a bit behind and probably not going to get my car finished today. I'm assuming this means they hadn't started on it at all yet because he didn't mention anything had been done or any problems. He did say he is going to work on it tomorrow to try to get it done for me before they lock the gates for a month, so I appreciate that. Especially as he is getting married on Sunday :P
Edited by Hanaldo
Possibly time for another update...
Problems. Huge problems. I've got no idea how/why/what happened, but somehow my ECU is corrupt. Sean couldn't get it started on Saturday as the maps are scrambled all over the place. He even tried starting again from scratch, but apparently nothing made any difference, ECU is just completely messed up. As he is now away on leave, he organized with my old tuner just down the road to get it finished, and I just got off the phone with him. He has got a new ROM for the ECU, so tomorrow he is going to try installing the new ROM to see if that works, but if not then it's the ECU. In which case, I may be digging into my Europe-trip funds to pay for a Vipec V44 plug in :( Don't see the point of replacing the stock ECU again when I plan on switching to a Vipec sometime down the track anyway.
Guess it is now just a waiting game to determine whether this tune is a $500 exercise as expected, or a $4000 exercise :/
so your idle problem was just a dud one way valve for the BMC?
ive been thinking of replacing mine as I can pump my brakes at a standstill and it pulls too much vac and drops the revs etc..
Care to enlighten me as to where you found such an awesome thing?
Idle problem??? Never had any serious idle problems... I had to replace the brake booster check valve as I accidentally busted the stock one trying to relocate it into a new hose.
But if it helps, I got it from CBA :)
Forgot to update this.
Decided on Friday to purchase this:
Along with Haltech 3 bar MAP sensor and IAT sensor, so will be doing away with the AFM now too. Hoping against hope that this finally sorts out my issues and gets the car running, will find out maybe Wednesday/Thursday this week with any luck :/
It will be awesome man!!! Now you can do a nice intake pipe for more Bling ;)
It'll be good to see the results coming from both cars soon! Shame its a bit far away to cruise with you though unless the meet up point is Alice Springs? :P
Haha yehhhhh, unfortunately I don't think my car would make it that far, I couldn't even trailer it from point A to point B without breaking something :P
Will get a 4" intake pipe made up some time in the future, but for now I need to recover funds. This ECU wasn't meant to happen for another 6 months at least, so I'm running on empty at the moment :(
Yeah Mongrel is going to finish ahead of me :dry:
LOL
Good luck man, cant wait!! :w00t:
yeah but not on the track
its kinda funny as the 3 of us are basically building the same car well that is if Hanaldo dont bitch and uses e85
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I can do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
    • The funniest part I saw, was someone would bitch and moan on FB about something, Andy would be the one to respond, asking for more info, if he could contact them, what the engine setup is, what their config file was, and 95% of the responses were people just going "der! It doesn't work" and Andy going "What doesn't work?" And then going "The firmware!" And they'd go around in circles as no one could ever give information, and Haltech couldn't fault things on the bench, (especially when people wouldn't give any specifics).   Many moons ago, when Andy was back at e420c stage, he reached out to me, and asked me to test different plug and play looms for him (already had an e420c in the car on his V1 PNP loom). And he kept asking me, as I was competent enough to be able to give him some specific feedback on what was/wasn't working, how to replicate the faults etc, and work through things with him. Most people are terrible at answering the questions they're asked, or being able to provide quality feedback other than "it doesn't work".
    • I say it often, none of this stuff is really Skyline-specific per se. But in general there's not a lot of people who actually know what they're doing. A lot of people charging like they do. Agile software development probably isn't the greatest idea for an engine controller.
    • Incidentally, I also put v3 of the tune on the car and did an oil change from 5w20 to 5w40 to see how it affected oil pressure in the mid to high end. I'm still happier with the thicker oil and will stick with it, but clearly the system is happy with 55psi even if I'm not! It's well within the service manual specs...but they are very open
